Type of variables mer ,tmpmonth, tmpday,tmphour,tmpminute
  • Thread starter Thread starter nnnnn
    Type Variables
The discussion focuses on the variable types in FORTRAN, specifically for the variables "mer", "tmpmonth", "tmpday", "tmphour", "tmpminute", and others. According to established conventions from older FORTRAN versions like FORTRAN 77, variable names starting with letters i through n are classified as INTEGER, while those starting with other letters are classified as REAL. Therefore, "mer" is identified as INTEGER, while the other variables are classified as REAL. Additionally, it is crucial to define variables before use to avoid warnings such as "Variable MER is used before its value has been defined."
  • Understanding of FORTRAN programming language
  • Familiarity with variable naming conventions in programming
  • Knowledge of data types: INTEGER and REAL
  • Basic debugging skills to handle variable definition warnings
  • Research FORTRAN 77 variable naming conventions
  • Learn about variable initialization in FORTRAN
  • Explore data type handling in modern FORTRAN versions
  • Study best practices for variable management in programming
Programmers working with FORTRAN, especially those maintaining legacy code, and anyone interested in understanding variable types and initialization in programming languages.
nnnnn
type of variables " mer ,tmpmonth, tmpday,tmphour,tmpminute"
May you kindly help me with :
1 . the type of following variables ( in FORTRAN ) ?
mer ,
tmpmonth, tmpday, tmpyear and
tmphour,tmpminute,tmpsecond,tmphund
2 . " Warning: Variable MER is used before its value has been defined "
how it must be defined ? and also about all above variables .
Much much thanks
Technology news on Phys.org
For 1, I don't know if the current versions of FORTRAN still do this, but the older versions, like FORTRAN 77, used to assocation types with variable names. Names that started with i, j, k, l, m, or n were INTEGER. Variable names that started with other letters were REAL.
So, if that rule is still applicable, mer is of type INTEGER, and all the others are of type REAL.
2. You should never use a variable before it has been defined; i.e., given a value.
  • · Replies 25 ·
  • · Replies 16 ·
  • · Replies 43 ·
  • · Replies 27 ·
  • · Replies 59 ·
12K
