| Thread Closed |
magnetic field of a solenoid |
Share Thread | Thread Tools |
| Oct30-09, 06:46 AM | #1 |
What would be the magnetic field of a solenoid if the wire of the solenoid itself is made up of another solenoid? I would be glad to hear any explanation about it.
| Oct30-09, 07:02 AM | #2 |
Admin
One would have an azimuthal field (from the smaller diameter windings) superimosed on an axial field (of the larger windings).
| Oct30-09, 07:24 AM | #3 |
Mentor
Thread moved to Classical Physics.
Hmmm, it seems to me there would be only the azimuthal field within the windings. No appreciable axial field, since that is outside the solenoid that makes up the windings. |
| Oct30-09, 07:45 AM | #4 |
Mentor
magnetic field of a solenoidIf you're really masochistic, you can calculate that when the two solenoids aren't coaxial. I think if the original question were clarified, the answers would be clearer as well. |
| Oct30-09, 08:07 AM | #5 |
Mentor
My understanding of the solenoid's configuration is something like this:
Vanadium seems to have a different picture in mind, so yes some clarification by the OP would be helpful. |
| Oct31-09, 08:17 AM | #6 |
I think that both fields will exist, but the axial magnetic field will be weakened a result of reduced axial alignment between magnetic dipole moments. If one passes changing direct current going one direction in the windings, I think an axial POLAR electric field will be produced by the changing azimuthal magnetic flux, and that this electric field could be in excess of the axial polar magnetic field that is produced by the changing azimuthal electric flux. If the power density is high enough, this could have some interesting properties, such as the ability to accelerate negative ions in one direction. |
| Oct31-09, 04:11 PM | #7 |
Smythe "Static and Dynamic Electricity" 3rd edition pages 296-297 solves the field in a helical solenoid.
Bob S |
| Oct31-09, 04:22 PM | #8 |
I think two magnetic fields will be in this system: one in the primary coil and another in the secondary. They will not be superimposed but separated - confined inside the corresponding coils.
| Oct31-09, 04:36 PM | #9 |
Bob S |
| Oct31-09, 05:21 PM | #10 |
The magnetic field outside a regular solenoid is much weaker than inside so we can speak of a field jump within the wire "wall". I do not speak of the magnetic field inside a wire.
| Oct31-09, 06:03 PM | #11 |
Mentor
1. Is oriented azimuthally, within the coils of the smaller outer solenoid, and 2. A weaker field is within the large solenoid, along the axis. (It would be weaker because of the smaller turns-per-length of the large solenoid, I suspect.) 3. A much weaker field, taken to be zero in the infinite-length limit, is outside both solenoids. |
| Oct31-09, 06:12 PM | #12 |
Mentor
∫loopB·dr = μo Ienclosedfor a loop that is partially inside, partially outside the solenoid, tells us there is an axial field inside the large solenoid. |
| Oct31-09, 06:38 PM | #13 |
I think there will be two spiral fields of different tensions, the spiral step being determined with d/D. (The wire thickness is taken to zero). If d<<D then both will be azimuthal, with no axial components. By the way, outside the big coil the field will be also spiral, that's my feeling.
| Oct31-09, 07:05 PM | #14 |
Mentor
Yeah, I agree about an azimuthal field outside both coils. But I think it's axial inside the large main coil.
Aside: At any rate, the smaller outer coil will have this "azimuthal" field (azimuthal w.r.t. it's "axis"), which would result in an axial field inside the large main solenoid.In fact, a normal solenoid would have an azimuthal field outside as well. So, to summarize, I think we would have: 1. An axial field within the large main coil, of strength B = μo n1 Iwhere n1 is the turns-per-length of the main coil. 2. An azimuthal field within the smaller outer coil, of strength B = μo n2 Iwhere n2 is the turns-per-length of the small coil Note that n1 < n2, so that field #1 is weaker than field #2. 3. Finally, an azimuthal field outside both coils, of strength B = μo I / 2πrwhere r is the distance to the central axis. This field would be the weakest of the three, since typically r >> 1/n1 > 1/n2where 1/n is the spacing between adjacent turns in a coil. EDIT: If both coils are of the same handedness, then fields 2 & 3 are in the same direction. If they are of opposite handedness, the fields point in opposite directions. |
| Nov1-09, 07:40 AM | #15 |
I vote for three spiral fields. The actual arrangement of wires is extremely important.
| Nov7-09, 01:31 PM | #16 |
now how if the same solenoid (which is made up of another solenoid) i.e the 1st solenoid is hollow in the inside and we have a liquid metal flowing within it? (considering fluidity, waves, magnetohydrodynamics)
| Nov7-09, 01:53 PM | #17 |
http://ntrs.nasa.gov/archive/nasa/ca...2007019809.pdf There are also generators (homopolar) based on the Lorentz equation. See http://en.wikipedia.org/wiki/Homopolar_generator [added] There is the possibility that a constant B field aligned with the direction of flow of a conducting liquid might reduce turbulence for high Reynold's numbers (just a guess). Bob S |
| Thread Closed |
| Thread Tools | |
Similar Threads for: magnetic field of a solenoid
| Solenoid Magnetic Field | Introductory Physics Homework | 11 | ||
| the magnetic field of a solenoid | General Physics | 1 | ||
| magnetic field of solenoid | Classical Physics | 3 | ||
| Magnetic Field and Electric field outside a long solenoid | Advanced Physics Homework | 5 | ||
| Magnetic Field outside AC Solenoid | Electrical Engineering | 2 | ||
