Lack of Relativistic Consideration
  • Context: Graduate
  • Thread starter Thread starter pzona
    Relativistic
The discussion revolves around the role of relativistic effects in quantum theory, particularly concerning the behavior of electrons in atomic orbits. Participants explore how these effects influence atomic energy levels and spectra, with a focus on hydrogen and heavier elements.
  • One participant questions why relativistic effects do not seem to affect electron orbits in quantum theory, suggesting a possible connection to the uncertainty principle.
  • Another participant clarifies that the speed of the electron is approximately 1% of c, which may not be sufficient for significant relativistic effects, but notes that these effects do appear in atomic spectra at high precision.
  • It is stated that relativistic effects do influence atomic energy levels, particularly in hydrogen, where the speed of the electron is around c/137, leading to small but measurable effects.
  • Relativistic effects are mentioned as a reason for the yellow color of gold, prompting requests for further explanation.
  • A formula for the binding energy of an electron in the hydrogen atom is provided, indicating that a complete treatment requires the relativistic Dirac equation.
  • Participants discuss whether the significance of relativistic effects in heavier elements is due to the size of the nucleus, electron configuration, or a combination of both factors.
  • One participant references a specific equation from a textbook for a complete relativistic solution for the hydrogen atom and notes that as the energy/mass ratio increases, relativistic effects become more pronounced.
  • A personal experience is shared regarding the calculation of reduced mass correction for pionic atoms, highlighting the significance of relativistic corrections in that context.
There is no consensus on the extent to which relativistic effects influence electron behavior in quantum theory, with multiple viewpoints presented regarding their significance and the conditions under which they become relevant.
Participants express uncertainty about the thresholds for significant relativistic effects and the specific conditions under which these effects manifest in atomic structures.
pzona
This may be a basic question; I'm not sure because I'm just getting into quantum theory. As I understand it, the electron orbits somewhere around the order of n x 10^6 (based on calculations I've seen). Moreover, the wave model of the electron suggests that it moves at velocity c. From this, I draw the conclusion that relativistic effects should apply since the electron is moving at a velocity close to c (I consider n x 10^6 to be "close"; perhaps this is part of my flaw), or at c. Obviously there's something wrong with this conclusion, but I'm not sure what it is.
I guess a simplified version of what I'm asking is: why don't relativistic effects affect the orbit of the electron in quantum theory. I have a suspicion it has to do with the uncertainty principle, but I really have no clue. I apologize if there are recent threads on this, but I couldn't go through all of them to make sure. Does anyone have a relatively simple answer (I know this isn't a simple matter), or does anyone have any links to some basic explanations of this?
If that's in meters/sec, it's only on the order of 1% of c. Try calculating (for example) the relativistic time dilation factor for that speed.
Relativistic effects do show up in atomic spectra, but only at fairly high precision. They help produce what is called "fine structure" in the energy levels and spectra.
Short answer - they do. Relativistic effects do influence atomic energy levels.
For hydrogen, though, the effect is small: v = c/137, but v2 is the figure of merit, and (v/c)2 is about 5 x 10-5. You need to get to middleweight-to-heavy nuclei befoe the effect is large.
Gold is yellow because of relativistic effects.
That's very interesting, could you explain?
The binding energy of an electron in the hydrogen atom is:
E = -(1/2) α2 m0c2,
where α = 1/137 and m0c2 is the electron rest mass.
Exact treatment of the electron orbit requires the relativistic Dirac equation.
Bob S
Interesting, thanks for the link. Are the relativistic effects significant more because of the size of the nucleus or because of the electron configuration? Or since more protons usually translates to more electrons (and thus they fill higher energy levels), is it a combination of both?
In my earlier post, I wrote only the first term in the expansion for the relativistic solution for the hydrogen atom. For complete relativistic solution see Schiff "Quantum Mechanics" second edition page 337 eqn 44.27.
For higher Z atoms, the 1s energy level is
E = -(1/2) α2Z2 m0c2,
As E/m0c2 gets larger, the relativistic effects increase.
[edit] When I had to once calculate the reduced mass correction for pionic atoms (using the Klein-Gordon wave functions), the difference between the relativistic and non-relativistic correction was significant.
Bob S
  • · Replies 21 ·
  • · Replies 87 ·
9K
  • · Replies 38 ·
