A few questions about the Lorentz factor
  • Context: Graduate
  • Thread starter Thread starter kotreny
    Lorentz Lorentz factor
The discussion revolves around the Lorentz factor (\(\gamma\)) and its implications in the context of special relativity, particularly concerning faster-than-light speeds, mathematical relationships, and the use of hyperbolic functions. Participants explore theoretical and mathematical aspects, including the geometry of triangles related to relativistic concepts, and the implications of rapidity.
  • One participant questions the consequences of faster-than-light speeds, noting that \(\gamma\) would involve complex numbers and speculating on potential physical implications like wormholes.
  • Another participant draws a connection between \(\gamma\) and the derivative of arcsin, providing historical context about the use of trigonometric tables in physics.
  • Integration of \(\gamma\) with respect to velocity leads to a relationship with arcsin, suggesting a geometric interpretation involving circles and arc lengths.
  • Hyperbolic functions are proposed as more suitable than trigonometric functions for describing relativistic motion, introducing the concept of rapidity and its properties.
  • A participant notes the difference in travel time for continuously accelerated motion compared to Newtonian predictions, emphasizing the role of light-travel time.
  • Discussion includes the additive nature of rapidity and its relationship to proper acceleration and Lorentz transformations.
  • One participant expresses curiosity about the mathematical implications of faster-than-light speeds and seeks clarification on the meaning of complex numbers in this context.
  • Another participant introduces a new triangle to illustrate length contraction, proposing a visualization of space "tilting away" during motion.
  • There is a mention of expressing space and time in the same units, leading to a discussion on the implications for mass and energy in theoretical frameworks.
Participants express various viewpoints on the implications of the Lorentz factor and related concepts, with no clear consensus on the interpretations of faster-than-light speeds or the best mathematical approaches. Multiple competing views remain regarding the use of trigonometric versus hyperbolic functions and the geometric interpretations of relativistic effects.
Some discussions involve assumptions about the mathematical relationships and physical interpretations that may not be universally accepted. The exploration of complex numbers in relation to faster-than-light speeds remains unresolved.
kotreny
I have only a rudimentary knowledge of the subject and would like more info about:
1)
The consequences of faster-than-light speed. I noticed that [tex]\gamma[/tex] would then involve complex numbers, and seeing as complex analysis is definitely more than imaginary, I was wondering what it could mean, both mathematically and physically (wormholes?). Unfortunately, I haven't gone very far into math higher than calculus yet. Hopefully soon to change.
2)
[tex]\gamma[/tex] bears more than a passing resemblance to the derivative of arcsin. Details?
You are nearly right. When I started high energy physics ~50 years ago, we did not have pocket calculators. We had only slide rules and trig tables. If you look up β in the sin(θ) column of the trig tables, then cos(θ) = 1/γ.
Consider β = 1/2. Look up sin(θ) = 1/2, and find cos(θ) = 0.86603, so γ = 1.155
Also if you set one side of a right angle triangle to the rest mass and the other side to the relativistic momentum (in energy units) then the hypotenous is the total energy.
So who needs pocket calculators?
Bob S
If you integrate [tex]\gamma[/tex]=c/(c^2-v^2)^.5 wrt v, then you get c*arcsin(v/c), since c is constant.
Geometrically, this means if you have a point on a circle of radius c, with vertical component v, then the angle will be arcsin(v/c) in radians. Multiplying this by c will yield the arc length. [tex]\gamma[/tex] is therefore dS/dv, S being arc traversed, measured in units of velocity.
That's about as far as I've gone. No idea what it means though; still learning the ropes. Don't forget to address 1)--suggesting some online resource or book would be helpful.
hello kotreny-
Please look at my thumbnail. I have drawn 3 triangles, all with the same included angle θ.
One triangle is your description, one shows the relationship between β γ and θ. the third shows the relation between total energy, momentum (in energy units), and rest mass. See also the trig relations.
Please review.
Bob S
It turns out that there are good reasons for using hyperbolic functions (sinh, cosh, tanh) instead of trig functions (sin, cos, tan). The relevant equations then become
[tex]\begin{array}{rl}<br /> \sinh \phi & = \gamma \beta = \gamma v / c\\<br /> \cosh \phi & = \gamma \\<br /> \tanh \phi & = \beta = v/c \\<br /> \\<br /> p & = m_0 c \, \sinh \phi \\<br /> E & = m_0 c^2 \cosh \phi \\<br /> \end{array}[/tex]​
The quantity [itex]\phi[/itex] is called rapidity, and is another way to measure motion instead of velocity. At non-relativistic speeds, the rapidity approximates to v/c. The rapidity of light is infinite, relative to any inertial observer.
This is so cool. It makes more sense than ever.
Here's another one which I thought worth noting. The travel time, as seen by a stationary observer, for a continuously accelerated motion (from v=0 to v=0 again)...
t2 = 4.s/a + (s/c)2
...notice how it compares to the Newtonian version
t2 = 4.s/a
...thus differing only by the light-travel time component.
Really does make it all space-time rather than just space and time.
You didn't mention the best thing of all about rapidity - it, unlike velocity, is additive.
True.
Also the proper acceleration of an object is [itex]c \, d\phi / d\tau[/itex], where [itex]\tau[/itex] is proper time.
The Lorentz transform is
[tex]\begin{array}{rcrcr}<br /> ct' & = & ct \cosh \phi & - & x \sinh \phi \\<br /> x' &= & -ct \sinh \phi & + & x \cosh \phi<br /> \end{array}[/tex]​
remarkably similar to a rotation in Euclidean space.
Doppler blue shift is [itex]e^{\phi}[/itex]. Doppler red shift is [itex]e^{-\phi}[/itex].
One drawback, though. Rapidity is a scalar, not a vector. Think of it as the angle between two worldlines in 4D spacetime.
Thank you for the reply, Dr Greg, but I have yet to thoroughly familiarize myself with the hyperbolic functions! :redface: I look forward to reviewing this thread in the near future.
Hello Bob, interesting thumbnail. I will definitely explore this connection more deeply once I am comfortable with the formulas involved. I can see why the triangles are similar.
This is digressing, but I just noticed yesterday that if space and time were expressed in the same units, then c would be a dimensionless ratio, and E=mc^2 would officially allow energy and mass to be expressed in the same units as well. Imagine: a unit for both space and time!
Again, could someone please give me more info about the mathematical results of faster-than-light speed? At least let me know if there's a proof that the complex numbers involved cannot have meaning. Thanks.
I found another triangle that should be added to Bob's three. It puts a new perspective on length contraction.
The hypotenuse is L (the rest length), the opposite side is [tex]\beta[/tex]L, and, interestingly, the adjacent is L*sqrt(1-[tex]\beta[/tex]^2). It's easy to see that the triangle is similar.
My interpretation is this: Visualize a circle, tilted at an angle to you. The circle will look like an ellipse in your view, and by my calculation the minor axis will be the diameter times the cosine of the tilt angle. The length contraction would be calculated in exactly the same manner if the circle were moving relative to you. Also note that when an object is tilted, there is no change along the axis of revolution.
Could this mean that, somehow, space "tilts away" when there is motion? It also makes it easy to see that contraction of the other is observed in both frames of reference, because the "tilt" is the same in both perspectives, just in opposite directions.
Hi Kotreny-
You need to read this paper in Phys Rev
http://prola.aps.org/abstract/PR/v116/i4/p1041_1
Sorry, it is pay per view.
Bob S
This is exactly what we do, actually. Typically we choose the units such that c = 1 (a dimensionless number). In these units, mass and energy have the same dimensions, as do time and distance. In fact, mass has the same units as 1/length.
Theorists sometimes confuse the rest of us by setting many fundamental constants to "1" for convenience; like hbar=c=1. This makes it very hard to detemine the units of an equation.
Bob S
  • · Replies 101 ·
  • · Replies 23 ·
  • · Replies 55 ·
  • · Replies 21 ·
  • · Replies 46 ·
9K
