Thread Closed
Efficiency of Carnot Engine Question
Share Thread Thread Tools
Oct30-09, 09:29 PM   #1
This is from "Equilibrium Statistical Physics" by Plischke and Bergerson, problem 1.1:
"Consider a Carnot engine working between reservoirs at temperatures T1 and T2. The working substance is an ideal gas obeying the equation of state [ [tex]PV=Nk_BT[/tex] ], which may be taken to be a definition of a temperature scale. Show explicitly that the the efficiency of the cycle is given by
[tex]\eta=1-\frac{T_2}{T_1}[/tex]
where [tex]T_1>T_2[/tex].
2. Relevant equations
The first law of thermodynamics, the ideal gas law, and a few other things. I'll introduce these in my partial solution; I hope that's not inappropriate.
3. The attempt at a solution
Well, I began by noting that the efficiency is defined as [tex]\eta=\frac{W}{Q_1}[/tex]. We also know that [tex]W=Q_1+Q_2[/tex], using the convention that heat leaving the system is negative. For the sake of reference, I will define that the Carnot engine moves through points A, B, C, and D, and that AB is isothermal at temperature [tex]T_1[/tex], BC is adiabatic, CD is isothermal at temperature [tex]T_2[/tex], and DA is adiabatic. For the process from A to B, since it is isothermal, the internal energy does not change. By the first law of thermodynamics, we have that:
[tex]dU=0=\bar{d}Q-\bar{d}W[/tex] and, thus, [tex]\bar{d}Q=\bar{d}W[/tex]
Next, we have that [tex]\int_A^B \! dQ=\int_A^B P \, dV=Nk_BT\ln(\frac{V_B}{V_A}[/tex]. Likewise, [tex]Q_2=Nk_BT\ln(\frac{V_D}{V_C})[/tex]. Simplifying the equation for [tex]\eta[/tex], we have:
[tex]\eta=1+\frac{\ln(\frac{V_D}{V_C}}{\ln(\frac{V_D}{V_C}}[/tex]
I understand that, for an adiabatic process, [tex]TV^\gamma=(constant)[/tex] and that [tex]\gamma=\frac{C_D}{C_V}[/tex], but I have no idea how to use this information to further reduce [tex]\eta[/tex] to the desired result --
[tex]\eta=1+\frac{T_2}{T_1}[/tex]
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Oct31-09, 12:01 AM   #2
From adiabatic process (BC and DA), we have:
[tex]
T_{2} V_{b} ^\gamma ^- ^1 = T_{1} V_{c} ^\gamma ^- ^1
[/tex]
[tex]
T_{2} V_{a} ^\gamma ^- ^1 = T_{1} V_{d} ^\gamma ^- ^1
[/tex]
From 2 eq, we shall get:
[tex]
\frac{V_{b}}{V_{a}} = \frac{V_{c}}{V_{d}}
[/tex]
Plug it to efficiency to get a result.
Oct31-09, 12:12 AM   #3
Ha, that's so obvious!! Thanks!
How do I mark this thread as "Solved"? I tried looking under "Thread Tools" but I didn't see an option for doing that...
Thread Closed
Thread Tools
Similar Threads for: Efficiency of Carnot Engine Question
Thread Forum Replies
Carnot Engine question- quick check Introductory Physics Homework 8
Something > Carnot efficiency ????? WTF? General Physics 11
Quick Carnot Engine Question Introductory Physics Homework 1
Carnot engine efficiency problem Introductory Physics Homework 2
Carnot Engine - Carnot Refrigerator Introductory Physics Homework 2
