Say gravity were larger, matter burns faster?
  • Context: Graduate
  • Thread starter Thread starter Spinnor
    Gravity Matter
The discussion explores the implications of a hypothetical universe with stronger gravitational interactions, focusing on how this would affect star formation, lifespans, and the potential for life. Participants consider the effects of varying the gravitational constant (G) and its relationship with other fundamental constants.
  • Some participants propose that a stronger gravitational force would lead to faster burning of matter in stars and black holes, potentially shortening the lifespan of stars.
  • Others argue that the specifics of how gravity changes, particularly in relation to dimensionless fundamental constants, are crucial to understanding the implications of a stronger G.
  • A participant suggests that if G were increased, the pressure within stars would also increase, leading to higher fusion rates, which could result in smaller stars that burn faster.
  • Some participants express uncertainty about the implications of changing G without altering other constants, questioning whether such changes would measurably affect stellar processes.
  • A later reply mentions a fictional universe where G is significantly stronger, leading to stars that are much smaller and have much shorter lifespans.
  • There is a suggestion that numerical simulations could provide insights into these scenarios, particularly in the context of fine-tuning problems in cosmology.
  • Participants discuss the need for broader research that includes all parameters of the Standard Model and their effects on various astrophysical phenomena.
  • Some express skepticism about the assertion that G is not fundamental, emphasizing its importance in certain contexts like stellar interiors.
Participants do not reach a consensus on the implications of a stronger gravitational constant, with multiple competing views and uncertainties remaining about the relationships between G and other fundamental constants.
Limitations include the complexity of the theoretical framework surrounding gravitational interactions and the dependence on the definitions of fundamental constants. The discussion reflects a variety of assumptions and speculative reasoning regarding the nature of gravity and its effects.
Spinnor
Say gravity were larger, matter "burns" faster?
Say we want a universe with a stronger gravitational interaction.
How does a stronger gravitational force effect star birth, life, and death?
Would matter in such a universe "burn" off faster in stars and black holes?
Could we still have a long lived universe like our present universe if "things" were fine tuned?
Thanks for any help.
You need to be a little more specific about what you mean by "a universe with a stronger gravitational interaction". I assume you mean that G is bigger, but G cannot change in isolation. So do you mean that G increases without any change in any of the dimensionless fundamental constants, or do you mean that G increases with a corresponding change in the dimensionless fundamental constants (e.g. the ratio of the proton mass to the Planck mass).
We say the force of gravity is roughly 10^40 weaker then the other forces. Make it say ten times stronger then it is so it would be "only" 10^39 times weaker than the other forces.
Then the universe would act different, but my hope is "things" can be tweaked so long lived universes could exist.
Thanks for your help.
Sorry, there is not enough information there for me to tell what is implied. As Wiki says:
Both magnitude ("relative strength") and "range", as given in the table, are meaningful only within a rather complex theoretical framework
DaleSpam said:
I'm sorry I don't understand what you mean by gravity is 10^40 times weaker than the other forces. The key question is how the dimensionless fundamental constants change.
See http://math.ucr.edu/home/baez/constants.html
Note: big G isn't one of the constants that Baez discusses.
As for how things change inside stars, if G is bigger then the pressure is larger for a given mass since pressure is usually...
P = k. G. M2/R4 ...where k's value depends on the central concentration of mass.
Nuclear fusion rates change very, very sensitively with temperature and thus pressure (remember PV = nRT?) So a bigger G means more fusion for a star of the same mass in our Universe and smaller stars can initiate fusion. In Stephen Baxter's "Raft" he imagines a Universe in which G is a billion times stronger. Stars are only a mile across and burn for a year, fusing all the way to iron before they sputter out.
If gravity was stronger from the very beginning (= less weaker then other forces) then stars will be smaller and they will burn faster, so there will be less time for life to form. The number of protons in an average star is a function of the weakness of gravity, so it is a function of that 10^-39
Quite so. But doubtless there are subtle points we might miss in making such a big generalisation. Higher G means the Helmholtz contraction phase is longer and brighter, perhaps partly compensating for a shorter Main Sequence?
May be. In any case, are there any good numerical simulations? It is very interesting in a context of a 'fine tuning' problem.
Fred Adams wrote a paper recently about stars in other Universes which may well be relevant. Of course you could contemplate writing the paper yourself?
"[URL
Stars in Other Universes[/URL]
Exactly. G is not fundamental, only the dimensionless constants are. G describes our system of units, not the physics of the universe.
This is only true if some of the dimensionless fundamental constants also change (e.g. the ratio of the proton mass to the Planck mass). If G changes without a corresponding change in the dimensionless constants then the pressure would not measurably change nor would the reaction rates nor the intensity nor anything else that we could measure.
"[URL
Wonderful. Thank you.
It would be very interesting to make that research much wider:
1. Add all parameters of the Standard Model to the parameter space
2. Analyze not only stars, but also supernovas, planet formation, life chemistry etc.
Well that's a much bigger task and we really don't know why Standard Model parameters are what they are. Nor do we really know the intricacies of planet formation as well as we understand the stars.
As for life's chemistry... too hard!
I'm not sure that really follows. For some uses, like stellar interiors, its actual value matters. You're confusing underlying mathematical structure (which c = h = G = 1 preserves) for actual physical predictions (which c = h = G = 1 doesn't preserve.)
Why? You seem to be asserting rather than proving. I suspect you're wrong. Show me as you would a novice - because that's what our questioner is after all.
However changing G does change the Planck units and I'm unsure what that would do to large scale physics.
It does follow; the only physically significant constants are the dimensionless ones. But you are quite correct, I have been asserting rather than proving and that is bad form on my part. This topic came up in great detail in a previous thread where I worked out a couple of examples in detail. It certainly is not a mathematically rigorous proof, but it was sufficient for me:
https://www.physicsforums.com/showpost.php?p=2011753&postcount=55
https://www.physicsforums.com/showpost.php?p=2015734&postcount=68
  • · Replies 35 ·
  • · Replies 18 ·
  • · Replies 50 ·
  • · Replies 23 ·
