How do you tell if tan x=0.5371, is in radian or degree?
  • Thread starter Thread starter Nope
    Degree Tan
The discussion revolves around determining whether the value of x in the equation tan(x) = 0.5371 is expressed in radians or degrees, within the range of 0 to 2π. Participants explore the implications of the dimensionless nature of the number 0.5371 and its relationship to the angle x.
  • Participants discuss the nature of the number 0.5371 and its lack of units, questioning how this affects the interpretation of x. Some mention that there could be two possible angle values for x that yield the same tangent result, one in degrees and one in radians.
The conversation is ongoing, with various interpretations being explored. Some participants offer insights based on conventions in trigonometry regarding radians and degrees, while others express confusion about the implications of these conventions. There is no explicit consensus, but several productive points have been raised regarding how to approach the problem.
Participants note that the absence of a unit typically suggests radians, while degrees are considered to have a unit. There is mention of the need to switch calculator modes depending on the desired output, and some confusion exists around the correct interpretation of the problem.
Nope
How do you tell if tan x=0.5371, (0.5371)is in radian or degree? ([tex]0\leq[/tex][tex]x\leq[/tex][tex]2\pi[/tex])thanks
0.5371 is just a number. The argument, x, of tan(x), however, could be in radians or degrees.
Is that mean, there will be two answer for this?
In degree mode, i got 28.24 degree
radian: 0.492885...degree?
You asked if tan(x) = 0.5371, then is 0.5371 is in radians or degree? It is neither, 0.5371 is a dimensionless number.
Now, if you're asking whether or not X is in radians or degrees and what is it's value? Then the answer to that is there are 2 values of X that produce that result (~28 degrees and ~208 degrees) and X can be in radians OR degrees. Since you're typically making calculations on a calculator or computer, the device will want it in degrees or radians and you should be able to determine this. If it's in radians, instead of say 90 degrees, you'd enter it as [tex]\frac{\pi}{2}[/tex] which is roughly 1.5708 radians.
Oh, I was confused on something, that's why..
Thanks...
my trig teacher told me that a number is in radians if there is no unit after it. degrees however is not unitless
i assume your answer should be in radians and therefore you should use the degree mode on your calculator. if I am wrong, you can easily convert from radians to degrees by multiplying your answer by 180 over pi,. although it might be even easier to just switch to degrees on the calculators./yes
That's not a mathematical "law" but it is a pretty widely used convention. You might also say that if a problem just treats trig functions "as functions" with no angles or triangles involved, then you should think of the argument as being in radians. Degrees are used almost exclusively for "angle" problems while sine and cosine are used for much more.
Surely that's not what you meant to say! If your answer should be in radians then you should use radian mode!
  • · Replies 20 ·
