Physics of capacitors over frequency
The discussion revolves around the behavior of capacitors in an AC circuit, particularly in the context of a low pass RC filter. Participants explore the physical principles behind why capacitors behave as shorts at high frequencies and open circuits at DC, seeking conceptual understanding beyond mathematical representations.
  • One participant seeks a conceptual explanation for the frequency response of capacitors, questioning the physical mechanisms behind their behavior in AC circuits.
  • Another participant uses an analogy of traffic on a bridge to illustrate the concept of charge movement in a capacitor, suggesting that increased frequency leads to a buildup of charges, akin to traffic congestion.
  • A different participant references Ampere's law, explaining that the displacement current between capacitor plates is related to the time derivative of the electric flux, which increases with frequency, leading to higher displacement current at AC compared to DC.
  • Another contribution discusses the energy storage aspect of capacitors, noting that at higher frequencies, the rapid switching of charge direction prevents the capacitor from fully charging, resulting in lower voltage across the plates.
Participants express various viewpoints and analogies regarding the behavior of capacitors, but no consensus is reached on a singular conceptual explanation. Multiple models and interpretations are presented without resolution.
Some assumptions about the nature of displacement current and the role of electric fields in capacitors are discussed, but these concepts remain partially unresolved and depend on further clarification of definitions and principles.
PMASwork
(not sure if this belongs here or in the Electrical Engineering section)
Howdy-
Consider a low pass RC filter subjected to an AC source (i.e the "output" is the capacitor voltage).
I understand mathematically how to assess the frequency reponse of such a circuit.
What I am after is a conceptual description of why. Why do capacitors act as shorts to high frequency and open circuits at DC? I know that the Xc = 1/(jwC) representation shows this mathematically, but I am wondering what is really physically hapening behind the equation.
Applying an AC voltage to a capacitor moves charges from one "plate" of the capacitor to the other, then back. Somehow, if I increase the rate at which I am doing this, the peak-to-peak voltage across the capacitor begins to diminish (and the balance is applied across the series resistor). Why?
Thanks!
Well think of it this way, in a city you might have a highway with a 2-lane bridge that everyone needs to take. Eventually the cars will pile up there... kinda like the charges. Let's say traffice is not rush hour, and its going both ways. Well, then there will always be people turning around let's say and start going the other way.
Okay, i know that's a lame analogy but that's the best i could come up with on the spot.
To understand it physically, just look look at Ampere's law. The magnitude of the displacement current is proportional to the time derivative of the electric flux through a surface (that surface would be between the plates of the capacitor, where no "real" current passes through, yet a changing electric field sure does.) So basically increasing the frequency of your AC directly increases the displacement current between the plates of the cap. If you hooked up a DC source, the electric field wouldn't change in time, thereby zero displacement current between the caps (and zero "real" current of course.)
Well, also as you know capacitors are storages of energy. When D.C. is use, positive charges flow in one direction and negative charges flow in the opposite direction. As soon as the capacitor saves all the energy in the electric field between it's plates the process of the charges flowing stops.
When A.C. is use, the same phenomenon takes place, but there is one difference, the flow of charges starts to switch direction discharging the capacitor and then charging the capacitor in the other direction(changing polarity).
If the frequency of the source is change into a higher frequency, the amount of charge storage in the plates is less because the direction of the flow in going to switch faster not allowing the capacitor to get full of energy, having in this way less voltage at the plates of the capacitor. Because q>q' => V=q/C>q'/C=V'.
  • · Replies 16 ·
  • · Replies 32 ·
14K
  • · Replies 19 ·
  • · Replies 32 ·
