How to Express c in Terms of b in Quadratic Equations?
  • Thread starter Thread starter um0123
    Terms
The problem involves a quadratic equation of the form x^2 + bx + c = 0, where the roots r_1 and r_2 have a specific condition that their absolute difference is equal to 1. The task is to express c in terms of b based on this condition.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss how to express the roots in terms of b and c, and how the condition |r_1 - r_2| = 1 influences the relationship between b and c. There are attempts to manipulate the quadratic formula and explore the implications of the roots' properties.
The discussion is ongoing, with participants exploring different algebraic manipulations and questioning the correctness of their approaches. Some guidance has been provided regarding the relationship between the roots and the coefficients, but no consensus has been reached on the final expression for c in terms of b.
Participants express uncertainty about the relevance of the roots and the condition given in the problem. There is also mention of potential errors in algebraic steps, particularly when squaring both sides of an equation.
um0123
The roots of [tex]x^2 + bx + c = 0[/tex] are [tex]r_1[/tex] and [tex]r_2[/tex],
where [tex]|r_1 - r_2| = 1[/tex].
Express c in terms of b.
Im not even sure where to start with this problem, and i don't see how the roots are relevant. I just don't know what the question is asking.
Can you write r1 and r2 in terms of b and c? i.e. actually find the roots.
The condition then says that the difference between these roots must be 1. Using the roots that you found above, set their difference equal to one. When does this equation hold true? How must b and c be related to satisfy this equation?
The roots are very relevant. If r1 and r2 are roots of your quadratic equation, it can be written as (x - r1)(x - r2) = 0.
Multiply the product above and equate the coefficient of x with b, and the constant term above with c.
The other condition, |r1 - r2| = 1, says that either r1 = r2 + 1 or that r2 = r1 + 1.
(x - r1)(x - r2) =
[tex]x^2 -r_1x - r_2x -r_1r_2[/tex]
so how do i combine the middle terms to get a single coefficient for b.
um0123 said:
(x - r1)(x - r2) =
Take out a factor of x:
[tex] (x - r_1)(x - r_2) =<br /> <br /> x^2 -x(r_1+r_2) +r_1r_2[/tex]Also, be careful with your signs. The constant term should be +r1r2
okay, I am seeing it a little more now, but i still don't understand how to relate b and c. I guess you can say that c is the product and b is the sum (of the values r1 and r2), but that's not relating the two to each other. And i still don't understand why its important that the absolute value is equal to 1.
It is important because that is the condition that the question requires. Think about when you normally find the solutions to a quadratic equation; you will (normally) get two unique solutions? What the question is saying is that when you solve this particular one, the difference between these two roots is 1.
If you use the quadratic formula to solve the given equation, what two roots do you get?
So i have to use the quadratic equation on [tex]x^2 -x(r_1+r_2) +r_1r_2[/tex]
x = -(r_1+r_2) +- sqrt{(r_1+r_2)^2 - 4(r_1r_2)}/2
that hardly seems solvable, i know I am doing something wrong.
Apply it to the original equation to find x in terms of b and c.
sorry, i don't understand what you mean by apply it to the original equation.
[tex] x^2 + bx + c = 0[/tex]
Solving this gives:
[tex]x=\frac{-b+\sqrt{b^2-4c}}{2}[/tex]
and
[tex]x=\frac{-b-\sqrt{b^2-4c}}{2}[/tex]
The condition says that the difference between these is 1.
i understand that part, but i don't understand how i solve it. Can i use a systems of equations?
Well the [tex]|r_1 - r_2| = 1[/tex] part says that the difference between these two solutions must be 1.
How about you actually find the difference between the two solutions above and then determine what the relationship between b and c must be for this difference to equal 1.
so
[tex]\frac{-b+\sqrt{b^2-4c}}{2} - \frac{-b-\sqrt{b^2-4c}}{2}=1[/tex]
multiply each side by 2
[tex]-b+\sqrt{b^2-4c} - {-b-\sqrt{b^2-4c}=2[/tex]
simplify
[tex]-b+\sqrt{b^2-4c} + b +\sqrt{b^2-4c}=2[/tex]
-b and b cancel
[tex]\sqrt{b^2-4c}+\sqrt{b^2-4c}=2[/tex]
square both sides
[tex]b^2-4c+b^2-4c=4[/tex]
simplify
[tex]2b^2-8c=4[/tex]
divide everything by 2
[tex]b^2-4c=2[/tex]
add 4c to both sides and subtract 2 from both sides
[tex]b^2-2=4c[/tex]
divide by 4 on both sides
[tex]\frac{b^2-2}{4}=c[/tex]
is that all i can do? did i do it right?
or am i supposed to solve for b?
[tex]b^2-4c=2[/tex]
[tex]b^2=2+4c[/tex]
square root both sides
[tex]b=\sqrt{2+4c}[/tex]
Sorry for the bump, but i am worried i did this wrong, can someone tell me if i did this correctly?
Have another look at that step where you squared both sides.
In general, it is NOT true that [tex](a+b)^2=a^2+b^2[/tex]
in that case i don't know what to do...
You had the right idea, just a small error in the algebra.
[tex] \sqrt{b^2-4c}+\sqrt{b^2-4c}= 2\sqrt{b^2-4c}=2[/tex]
How about divide both sides by 2?
[tex] \sqrt{b^2-4c}=1[/tex]
Can you see what to do from there? For that equation to hold, how must b and c be related?
omg, thank you so much!
So you see it now? :smile:
Glad to be of assistance :)
  • · Replies 19 ·
  • · Replies 23 ·
