| Thread Closed |
How is nuclear energy harnessed? |
Share Thread |
| Nov1-09, 10:42 AM | #1 |
I understand how it is that nuclear processes release energy during fusion reactions, but i don't know how that energy is used to create positive work. I know radiation is produced as well as heat, but what techniques are used to convert these to usable and storable(not a word, i know) forms of energy?
| Nov1-09, 03:04 PM | #2 |
All that energy released in fission heats up the nuclear fuel in the core. A cooling fluid is pumped through the core. Depending on the plant design, the working fluid powers a turbine or transfers its energy through a heat exchanger to another loop that runs a turbine.
| Nov1-09, 04:40 PM | #3 |
Mentor
In other words, a nuclear plant works fundamentally the same as any steam power plant, just with the heat being generated in a different way.
Note that due to the lower temperature of steam pluss losses due to the extra piping, and heat exchanger, the thermodynamic efficiency of a nucler plant is lower than a most other types of steam engines. |
| Nov3-09, 07:08 AM | #4 |
How is nuclear energy harnessed?And remember, the uranium isn't really useful for anything else, other than WMD. So the statement that "the thermodynamic efficiency is lower" is true, but it isn't very meaningful in the context of comparing different power stations. |
| Nov3-09, 08:29 AM | #5 |
| Nov3-09, 09:33 AM | #6 |
A simpler answer to the original question: Nuclear plants work they same way as any other thermal (heat) generation station. The only difference is how the heat is produced. In a nuclear plant that comes from nuclear reactions in the fuel, in a coal plant it comes from burning coal. In both cases the heat is used to boil water creating high pressure steam. This steam goes to a turbine which spins a generator. Nuclear plants tend to an extra heat exchanger that other types of plants don't have. Basically hot water from the reactor is used to heat water in a different set of pipes. This keeps the water in the reactor separate from the water on the turbine side. Unfortunately, this extra heat-exchanger wastes some energy but is needed for other reasons. That is what they are talking about when they say lower thermodynamic efficiency. |
| Nov3-09, 09:41 AM | #7 |
But the point is, the fuel 'usage' in a reactor is a few tons per year, vs. more than 200 tons per *hour* in a coal burner. |
| Thread Closed |
Similar discussions for: How is nuclear energy harnessed?
| Nuclear Energy | General Physics | 4 | ||
| Nuclear energy at sea | Nuclear Engineering | 24 | ||
| Nuclear Energy | Nuclear Engineering | 24 | ||
| Feasibility of Nuclear Energy with Recycling (Pu) as Energy Solution in US | Current Events | 34 | ||
| Nuclear Energy | Introductory Physics Homework | 1 | ||
