New Reply
4 vectors perpendicular to four faces of tetrahedron. Show that the sum = zero vector
Share Thread
Nov1-09, 04:00 PM   #1
Four vectors are erected perpendicular to the four faces of a general tetrahedron. Each vector is pointing outwards and has a length equal to the area of the face. Show that the sum of these four vectors is zero.
2. Relevant equations
3. The attempt at a solution
Let A, B and C be vectors representing the three edges starting from a fixed vertex. Then, express each of the four vectors in terms of A, B and C.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Nov2-09, 01:29 AM   #2
I figured out how to do the problem.
But there's another part to the problem: Formulate and prove the analogous statement for a plane triangle.
What is meant by a "planar triangle"?
Nov2-09, 02:20 AM   #3
Recognitions:
Homework Helper Homework Help
i think it probably just means any normal triangle (normal in the sense that it is contained within in a plane in R^3, so planar)
can you show it for such? where i'm guessing the analogy is area to length
Nov2-09, 08:49 PM   #4
Recognitions:
Gold Membership Gold Member
Put your triangle in the xy plane; label the vertices A,B,C clockwise. Make vectors of the sides going from A to B, B to C, C to A (i.e, [itex]\vec a = B - A[/itex] etc.). Those side vectors add to the zero vector. Now rotate the triangle 90 degrees counterclockwise and they become perpendicular to the original sides pointing outward and the right length. Presto!
Nov22-10, 04:28 AM   #5
I am trying to solve this same problem. Would the person who asked the question and said he/she figured it out please tell me how its done? Unfortunately, it is just not clicking with me. Thank you.
Nov22-10, 04:32 AM   #6
Could you explain how you solved this?
New Reply
Similar discussions for: 4 vectors perpendicular to four faces of tetrahedron. Show that the sum = zero vector
Thread Forum Replies
find two perpendicular vectors which are perpendicular to another Calculus 14
Given perpendicular vectors A and B, solve A x Y = B for Y Precalculus Mathematics Homework 1
Finding a vector perpendicular to two vectors Calculus & Beyond Homework 6
Proving perpendicular vectors Precalculus Mathematics Homework 7
Find all vectors in R^3 that are perpendicular to [1; 3; -1] Linear & Abstract Algebra 1
