| Thread Closed |
How would you see an Event horizon? |
Share Thread | Thread Tools |
| Nov1-09, 04:07 PM | #1 |
As I understand it, an Event Horizon is a boundary surrounding a black hole where light is held 'still'. If the photons never get beyond this boundary, how can they be observed?
| Nov1-09, 05:07 PM | #2 |
Recognitions:
They don't get observed. That's why the black hole is black!
| Nov1-09, 06:02 PM | #3 |
The event horizon of a BH is not a boundary; it is simply a radius that defines a particular phenomenon. In simple terms: - a light ray passing tangentially, but outside, this radius will be bent sharply around the black hole but will continue off into space. - a light way passing tangentially, but inside, this radius will be bent so sharply that it will fall into the BH and not re-emerge. Likewise, any light rays that emanate from inside the EH will be bent around in a curve so that they will not exit the EH. But ultimnjately, as Nabeshin points out, a photon inside the EH will not exit and thus will not be observed. If a light ray happened to be perfectly aimed directly out from the centre of the BH, so that it could not be bent in any particular direction (like like balancing a pencil on its tip), the light ray does not stop moving, it is simply infinitely red-shifted. |
| Nov3-09, 04:05 AM | #4 |
Recognitions:
How would you see an Event horizon?The EH is indeed defined as a boundary. From mathpages: "The black hole region, B, of such a spacetime is defined to be the points of M not contained in the causal past of future null infinity. The boundary of B in M is called the event horizon." If we think of light as a classical particle, such a particle moving outwards at the EH would indeed have a constant r-coordinate, in this sense being "held still". So the EH is the boundary of the region you can't observe. |
| Nov3-09, 09:32 PM | #5 |
Photons observed entering a black hole by an observer inside the event horizon will be infinitely blue shifted, as Ich noted.
| Nov3-09, 09:46 PM | #6 |
Recognitions:
| Nov4-09, 03:25 AM | #7 |
Recognitions:
Note that you wouldn't even notice at what point you crossed 'inside' the event horizon if you fell into one (assuming you weren't ripped apart by tidal forces, lets assume you are very small and falling into a very large black hole). As photons fall into a hole, they gain a graviational blueshift (for observers at a smaller radius than the emmitters). This is determined by the difference in radius and the relativistic version of the gravitationl potential, which depends on the black hole mass. There is no discontinuity in this process at the Schwarschild radius. The only way to get an infinite gravitational blueshift is to have an infinite mass black hole, but that's just mathematical tomfoolery. |
| Nov4-09, 12:18 PM | #8 |
Mentor
http://www.physicsforums.com/showthr...97#post2417397. |
| Nov4-09, 04:06 PM | #9 |
Recognitions:
I think the only way to get infinite blue shifted photons, besides the infinitely massive BH Wallace notes, is to position our observer just outside the event horizon, and have him attempt to remain stationary (i.e fire rockets radially outward). Such an observer finds he needs to expend a near infinite amount of energy to remain stationary, which is related to his discovery of infinitely blue shifted radiation.
| Nov17-09, 02:44 AM | #10 |
Correct, Nabeshin. A stationary observer at the event horizon would perceive enormous blueshift. An observer in free fall would be less affected.
"What would you see from inside a black hole?" http://curious.astro.cornell.edu/que...php?number=348 “... Eventually at the event horizon there is an infinite shift - so the light has an infinite amount of energy, but zero wavelength. ...” I concede Karen Masters assumes this is only true for a stationary observer at the event horizon, as was my original assumption. "The edge of locality: visualizing a black hole from the inside" http://arxiv.org/abs/0903.4717 “... Near the singularity, the observer's view is aberrated by the diverging tidal force into a horizontal plane. The view in the horizontal plane is highly blueshifted, but all directions other than horizontal appear highly redshifted. ...” This assumes an observer in free fall inside the event horizon. This paper is a good read for the curious. "Journey into a Schwarzschild black hole" http://jilawww.colorado.edu/~ajsh/insidebh/schw.html “ ... Click on the image at left (with the horizon grid) or right (without the horizon grid) for an animation of the appearance of the outside Universe as you lower yourself SLOWLY [emphasis mine] to the horizon. The Universe appears brighter and brighter as you approach the horizon, tending to infinite brightness at the horizon. ...” The movies are great on this link. I don't make this stuff up, but, sometimes mix it up. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: How would you see an Event horizon?
| Event Horizon | Special & General Relativity | 1 | ||
| How does a photon's event horizon look like? | Special & General Relativity | 6 | ||
| Event Horizon | Special & General Relativity | 9 | ||
| Acceleration At The Event Horizon | Astrophysics | 29 | ||
