Viscous Flow and Pressure Coefficient
The discussion revolves around the effects of a large positive dCp/dX on real viscous flow, particularly in the context of airfoil design using thin airfoil theory and vortex panel methods.
  • Exploratory, Assumption checking
  • Participants explore the relationship between viscosity and pressure, with one suggesting that density and kinematic viscosity may be affected under ideal gas assumptions. Others seek clarification on specific properties of viscous flow and inquire about the dimensionality of the flow.
The discussion is ongoing, with participants providing insights and seeking further clarification. Some guidance has been offered regarding the relationship between lift coefficient and pressure coefficient, though no consensus has been reached.
The design context is specified as two-dimensional, which may influence the considerations being discussed.
snido727
What effect does a large positive dCp/dX have on the real viscous flow? This is for an airfoil design project using thin airfoil theory + vortex panel method.
As far as I know Viscosity is independent of pressure, so the only thing I can think of is assuming ideal gas behavior and saying that it affects the density and therefore the kinematic viscosity. However I believe that he is referring to something different, some property of a viscous flow that I haven't yet figured out.
Thanks in advance.
Can anyone help me? I don't need the answer so much as a nudge in the right direction...ie "look at x property"
Thanks again
in which dimension is flow?
The design is in 2 dimensions.
Well for anyone else who stumbles upon this and needs the answer look at the difference between the lift coefficient vs. angle of attack graph for viscid vs. inviscid flow, and consider how the coefficient of pressure affects the lift coefficient.
  • · Replies 18 ·
