Solving for Velocity and Force in a Rocket Problem | Conservation of Momentum
  • Thread starter Thread starter Cryphonus
    Rocket
The discussion revolves around a rocket problem involving conservation of momentum, where a small rocket ejects jet gas and the participants are tasked with determining the rocket's velocity after the ejection and the force exerted by the gas. The problem is situated in the context of classical mechanics, specifically focusing on momentum and impulse.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the application of conservation of momentum, questioning how to incorporate the time interval of gas ejection into their calculations. There are discussions about impulse and its relationship to momentum, with attempts to clarify the definitions and implications of these concepts.
The discussion is active, with participants sharing their calculations and reasoning. Some have provided insights into the relationship between impulse and momentum, while others are working through the implications of directional momentum. There is a recognition of the need to consider the direction of the expelled gas in calculations.
Participants are navigating the constraints of the problem, including the specific mass of the rocket, the velocity of the gas, and the time interval for ejection. There is an emphasis on understanding the definitions of impulse and momentum without reaching a definitive conclusion on the final answers.
Cryphonus
A small rocket of mass 1ton is moving horizontally with a velocity of 600 m/s in the x direction.The total force on the rocket is zero.10 kg of jet gas is ejected at a velocity (in the x direction) of -6000 m/s with respect to the ground.The ejection takes place over a time interval of 1 second.
a) What is the velocity of the rocket after the jet gas is ejected?
b) What is the force (vector) that the jet exerts on the rocket during the ejection?
P=m.v and the conservation of momentum
i don't know what to do because of the given statement "The ejection takes place over a time interval of 1 second". So i would be glad if you can clarify this mathematically and help me to add it into the equation about the conservation of momentum.(think its something to do with derivative)?
Conservation of momentum applies always, and in this case you only need cosider the initial & final states
To get the time invloved, look at impulse & how its related to momoentum.
Force is related to the derivtive of velocity through Newtons 2nd, though i don't think its required here
thanks for the info but i still have questions about the problem;
Impulse means the change of momentum in a given time which is basically expressed in the form I=m.ΔV or Force times t.So if i try to find the initial momentum of the rocket it is going to be: 600.1000=(Momentum for the final situation) so i know the initial momentum but i don't know how to add the impulse to the equation to calculate the final situation that i wrote in paranthesis.
no worries,
if you know the intial momentum of the whole system, by conservation of momentum, the final will be equal. You can work out the momentum of the gas, which should lead you to the final momentum of the rocket
then relate the momentum change to the force in b) through the impulse realtion
note that impulse is defined as F.t and is equal to the change in momentum (or the integral of F.dt if you're using calculus)
So for the answer of a)
i calculated the initial value of momentum which is 600.1000 and that equals to the final value which is 990.V-6000.10.So therefore 600.1000=990.v-6000.10
99V=54000
V=545.45
which is the new speed of my rocket =) am i correct?
close, if momentum was a scalar qunatity, but momentum has a direction attached, so you must honour the negative in the expelled gas
think of it this way, based on your numbers, the rockets cruising along (+ve x dir'n) shoots out heaps of gas behind (-ve x dir'n) and slows down (in the -+e x dir'n)?
you'd probably expect it would speed up hey?
lol yea i should have noticed that :/, it should speed up the rocket... i forgot to put a minus there;
so with the same calculations but with a minus infront of the momentum of the jet gas my new velocity for the rocket is 666.66 m/s.
and for the answer of b) i used the equation of:
F=m.a (m=the mass of the gas)
so since the ejection takes place over a time interval of 1 second;
acceleration for the gas= -6000m/s-0 /1s so acceleration is equal to -6000 m/s2
therefore the force vector on the gas is 60.000 N
Correct me if I am wrong :) thanks for the help so far...
  • · Replies 47 ·
  • · Replies 30 ·
  • · Replies 22 ·
