Rotation direction of an ac induction motor
The discussion revolves around the direction of rotation of single-phase and three-phase AC induction motors. Participants explore whether the rotation direction is fixed or variable, and under what conditions it may change. The scope includes technical explanations and practical experiences related to motor wiring and operation.
  • Some participants propose that single-phase motors can run in either direction depending on the wiring of the starting circuit.
  • Others argue that three-phase motors can also run in either direction based on how the three phases are connected to the motor.
  • A participant mentions that some motors are designed to allow users to change the direction with a switch.
  • It is noted that switching two phases in a three-phase motor will reverse its direction.
  • One participant shares an anecdote about a vacuum pump running backwards due to incorrect wiring of the motor phases.
Participants generally agree that both single-phase and three-phase motors can run in either direction under certain conditions, but there are multiple competing views on the specifics of how this is achieved.
There are limitations regarding the assumptions about motor designs and wiring configurations that may affect the direction of rotation, which are not fully explored in the discussion.
samieee
I want to know that is the direction of a single phase or three phase ac induction motor is fixed and it is clockwise? ...or it may be both anti-clockwise and clockwise..or it can be both directional for single phase and only clockwise directional for 3 phase?...thanks
Single phase motors can run either way,depending on how the starting circuit (capacitor start, split phase start, etc.) is wired.
Three phase motors can run either way depending on how the 3 phases are connected to the motor. I have seen vacuun pumps on large vacuum systems run backwards, because someone forgot how to wire up the motor phases.
Bob S
Some motors are designed so that the user can change the direction with a switch.
Yes and just switch two phases and it will run in the opposite direction.
thanks... I got my answer
Bob S
We did that once (cryopump compressor). It made a hell of a racket for the few seconds it was up while we were trying to figure out if that was the normal sound or not (though to be fair, the documentation just told us to hook it up, and switch two leads if we didn't think it was running properly).
  • · Replies 18 ·
