Which Research Maximizes PhD Program Chances?
  • Thread starter Thread starter jeremyphysics
    Research
The discussion revolves around the considerations for a physics master's student deciding between two research paths—experimental research in nuclear physics and theoretical research on the foundations of quantum physics—in terms of maximizing chances for acceptance into a PhD program. The scope includes aspects of research applicability, program alignment, and the perceived value of different research areas.
  • Some participants suggest that experimental nuclear physics may offer broader applicability to other fields, potentially enhancing PhD program acceptance chances.
  • Others argue that the relevance of research to a specific school's focus is crucial for acceptance, emphasizing the importance of aligning one's background with the program's research interests.
  • A participant questions the applicability of theoretical research on the foundations of quantum mechanics to other fields, seeking clarification on its relevance.
  • One participant expresses a strong negative opinion about the value of theoretical research in quantum mechanics, suggesting it lacks practical utility compared to other areas of physics.
Participants do not reach a consensus on which research area maximizes PhD program chances, with multiple competing views on the applicability and value of the two research paths discussed.
Participants highlight the dependence on specific school requirements and research interests, as well as the subjective nature of what constitutes valuable research in physics.
jeremyphysics
I am a physics masters student, I have the following choices of research:
Experimental Research in nuclear physics
OR
Theoretical Research on the foundations of quantum physics
Everything else being equal, meaning If I choose the experimental route, I will get equal grades, equal physics GRE scores, and equal letters of recommendation in comparison to the theoretical route. Which area of research will maximize my chances of getting into a PhD program?
Or phrased another way, which area of research do most PhD programs look for?
Thank You
It's really hard to say because things are school specific.
If you had to really pin me down, I'd say that the nuclear physics would be more useful, since there is an larger overlap between experimental nuclear physics and other seemingly non-related physics. For example, if you know nuclear physics, then you can get into a school in astrophysics which is interested in nucleosynthesis. If you can build instruments then you might be able to get somewhere where their is an opening in particle physics experimentalists.
Also you wouldn't happen to be at the College of William and Mary? If by "fundamentals of quantum physics" you mean stuff like what the Delos group is doing there, then that's a different situation since what they are doing there is generally applicable to unrelated fields of physics.
Oh no, I am not at College of William and Mary, but you mentioned their work on fundamentals of quantum mechanics may have applications to other fields? How applicable is research on the fundamentals of QM to other fields if at all?
So, if I understand your correctly, it is the applicability to other fields that, for the most part, determines which field of research has a higher chance of being accepted at a PhD program?
Thank You
It's applicable to philosophy :smile:. If "fundamentals" means "foundations" then philosophers will tell you that it actually just is philosophy. But then again you probably weren't considering philosophy as one of the other fields QM is applicable to.
See this guy for example: http://www.princeton.edu/~hhalvors/papers/ (yes, philosophers do publish in "Journal of Mathematical Physics" and "Physics Review A")
You tell me :-) :-)
The way it works is that (assuming that you have decent grades and a good basic background) what determines whether you get into a particular Ph.D. program is how well your skills and background fit with the schools research program. If you are absolutely interested in AMO physics, and the school's focus is string theory (or vice versa) you are less likely to get in.
So if you have research background which you can argue is relevant to the school's research interest, this will help. If you do nuclear physics, and the schools that you want to apply to are involved heavily in plasma physics, one thing that you do need to do in your statement of purpose is to explain how your background in nuclear physics will help the school's program in plasma physics (which is less difficult than it sounds).
Well, I can't think of any graduate work I've ever seen done that I think is more useless than the above. I've seen a few things that tie it.
Quantum mechanics is 70 years old. There's been a tremendous number of incredibly valuable physics that is important theoretically and practically discovered since then. There have been some marvelous advances in the past 15 years.
Why anyone would sit around "researching" vanilla QM is beyond me. What a waste of office space.
  • · Replies 20 ·
  • · Replies 59 ·
