Erroneous application of the quotient rule
The discussion revolves around a calculus problem involving the Quotient Rule and its erroneous application. The original poster describes a situation where a student, Zach, mistakenly applies a simplified version of the Quotient Rule to find the derivative of a function defined as a quotient.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the implications of Zach's incorrect application of the Quotient Rule and explore the resulting differential equation. There are attempts to clarify the relationship between the derivatives and the original function, as well as questions about solving the differential equation.
Several participants have provided guidance on the nature of the problem, suggesting that it can be approached as a separable differential equation. There is an ongoing exploration of integration techniques and substitutions, with participants engaging in a collaborative effort to clarify the steps involved.
Some participants note that the original poster has not yet covered differential equations in their coursework, which may affect their ability to fully engage with the proposed solutions. There is also mention of the need for antiderivatives and integration techniques relevant to the problem.
greenpick
Hello everyone, first time poster here. I've been a lurker for about a week, but finally decided to join because I cannot for the life of me figure out this problem.
Zach has trouble with the Quotient Rule; he thinks that d/dx (f(x)/g(x)) =
f′(x)/g′(x). On his last calculus test, Zach applied this erroneous rule to a quotient in which g(x) = x.
Somehow, he managed to get the right answer. What are all the possibilities for the function f(x)?
d/dx (f(x)/g(x)) = f′(x)/g′(x) (Zach's rule)
d/dx (f(x)/g(x)) = [f′(x)g(x) - f(x)g′(x)] / (g(x))^2 (actual quotient rule)
I first attempted to set the derivative using Zach's equation equal to the derivative using the quotient rule.
After simplification, I got
f(x) = (x-x^2)f′(x)
I am not really sure what to do at this point however. I am assuming it is something either really obvious, or really not-so-obvious. I tried using a substitution, and even an hour of trial and error, but I am just not seeing it. Am I going to have to use the limit definition of the derivative? Any help would be greatly appreciated.
Have you learned integration yet? This amounts to being a differential equation. What I mean is that you can solve for f by performing the following integration:
[tex]\int \frac{f'(x)}{f(x)} \,dx = \int \frac{1}{x(1-x)} \,dx[/tex]
f(x) = (x-x^2)f′(x) looks correct. No, you don't need any limits. Now it's a separable differential equation. Do you know anything about solving differential equations?
Isn't this exactly what I just posted?
Of course it is. I didn't see your post before I posted. Want me to delete it?
Haha. Sorry. No problem. There's no reason to delete. :)
Wow, thank you guys for the quick replies.
Fortunatly, we just started learning antiderivatives and the basics of integrals in class the end of last week. unfortunately, we haven't gone over differential equations with integrals. It appears that I need to find the antiderivative of 1 / [x(1-x)]. Is this correct? It looks like I am going to have to make a substitution.
This is just a shot in the dark, but would I...
let u = x(1-x) so that [tex]\int\frac{1}{x(1-x)}dx[/tex] becomes [tex]\int\frac{1}{u}dx[/tex] ?
But would I need to change dx to du in the second integral? would it then become
[tex]\int\frac{1}{u}du[/tex] ?
Am I on the right track?
First notice that
[tex]\frac{1}{x(1-x)} = \frac{1}{x} + \frac{1}{1-x}[/tex]
Then
[tex]\begin{align*}<br /> \int \frac{f'(x)}{f(x)} \,dx &= \int \frac{1}{x(1-x)} \,dx \\<br /> \ln[f(x)] &= \int \frac{1}{x} \,dx + \int \frac{1}{1-x} \,dx<br /> \end{align*}[/tex]
Can you finish it now?
Ah, I did not even notice that log derivative.
So I would have
[tex]\int\frac{1}{x}dx[/tex] + [tex]\int\frac{1}{1-x}dx[/tex] = ln(abs(x)) - ln(abs(1-x))
ln(abs(x)) - ln(abs(1-x)) = ln(f(x)) = ln(abs(x/(1-x)))
f(x) = e[tex]^{ln(abs(x/(1-x)))}[/tex] = abs(x/(1-x)) + C ?
So I would have
Yep!
Wow! Thank you guys so much that helped.
No problem! Congratulations on solving your first differential equation.
  • · Replies 25 ·
