What is the Maximum Velocity of a Person Falling from a 35 Meter Tower?
  • Thread starter Thread starter phuketman
    Falling Speed
The discussion revolves around a physics problem concerning the maximum velocity of a person falling from a height of 35 meters. The original poster presents a scenario involving a 69-kilogram individual falling head first and seeks to determine the maximum velocity reached before impact.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of kinematic equations related to uniform acceleration. Some express concern about the need for an initial attempt at a solution, while others provide hints and equations relevant to the problem. There is also a mention of the irrelevance of mass in determining the final speed of a falling object.
The conversation includes various attempts to guide the original poster towards using kinematic equations. Some participants have offered equations and insights into the relationship between fall distance, time, and acceleration due to gravity. There is an acknowledgment of the rules of the forum regarding attempts at solutions, and a supportive tone is present in the responses.
Participants note the importance of showing an attempt at a solution to receive help, as per forum guidelines. The original poster expresses uncertainty about their physics knowledge and seeks assistance for research purposes.
phuketman
A 69 kilogram person falls from a 35 meter tower head first to the ground
What is the maximum velicoity he reaches before impact?
See that #3? That's where you make an attempt at a solution.
We don't spoon-feed homework here.
Hint: Use your kinematic equations for uniform acceleration.
Sorry if I am a dumbum. I'm 57 and have forgotten all my equations, not that I was very good at physics. I am doing research for a stuntman who has survived this fall and want to know what speed he reached.
The https://www.physicsforums.com/showthread.php?t=5374" that you agreed to when you signed up require you to attempt a solution:
"NOTE: You MUST show that you have attempted to answer your question in order to receive help."
Furthermore, we are expressly requested not to do work for people here; this is afterall, and homework help forum.
V = Vo + at
X - Xo = volt + .5at2
v2 = vo2 + 2a(X - Xo)
X - Xo = .5(Vo + V)t
V is final velocity in units of meters per seconds (m/s)
Vo is initial velocity in units of meters per seconds (m/s)
a is acceleration in units of meters per squared seconds (m/s2)
t is time in seconds (s)
X is final displacement in units of meters (m)
Xo is initial displacement in units of meters (m)
The mass does not matter, any falling object will have the same speed after falling 35m.
First you need the time of the fall.
x = fall distance = 35m
a = acceleration due to gravity = 9.8 m/s
t = time of fall.
x = .5 a t^2
[tex]t = \sqrt { \frac {2x} a }[/tex]
Given the time of the fall the speed is
v = at
so [tex]v = \sqrt {2 a x}[/tex]
That should give you all the equations you need. can you take it from here?
thank you DaveC426913 and Integral. I am new to this board and appreciate your help.
I will not bother you again.
Feel free to bother. That's what we're here for. :wink: But there's rules is all.
  • · Replies 38 ·
