What Does the Mean Really Represent in Different Contexts?
  • Context: Undergrad
  • Thread starter Thread starter WiFO215
    Mean
The discussion revolves around the interpretation of the mean in various contexts, particularly in relation to dice and color assignments. Participants explore the implications of calculating the mean for discrete outcomes and the challenges posed by non-numeric categories. The conversation includes theoretical considerations and definitions related to means, probabilities, and random variables.
  • Some participants express confusion about the meaning of a calculated mean, particularly when it results in a value that cannot be realized, such as 3.5 from a standard die.
  • One interpretation suggests that as the number of rolls increases, the expected total approaches the number of rolls multiplied by the mean.
  • Concerns are raised about defining a mean for non-numeric categories, such as colors, with some arguing that colors cannot have a mean since they are neither cardinal nor ordinal.
  • Participants discuss the definition of the mean as a weighted average of possible values, emphasizing the role of probability in this calculation.
  • There is a distinction made between the observed mean (sample mean) and the theoretical mean (expected value), with questions about how to assign values to non-numeric outcomes.
Participants express differing views on the applicability of the mean to non-numeric categories and the interpretation of means in general. There is no consensus on how to handle the mean in the context of colors or non-ordered sets.
Some definitions and assumptions are not fully clarified, particularly regarding the mapping of colors to numerical values and the distinction between different types of means. The discussion remains open-ended with unresolved questions about the nature of means in various contexts.
WiFO215
I know what the definition of a mean is, but I'd like to know what it actually means. Let me give you an example. Suppose I have a regular dice, then the mean that I calculate using the normal process seems to say 3.5, although the dice will never realize that value. So what does it explain here?
What would the mean be if I had a dice with any 6 colors from VIBGYOR? In such a case, the mean isn't even defined properly is it? If I assigned each of the colors a number from 1-6, then I'd get a mean of 3.5 again which makes absolutely no sense. Odd to say that the mean in this case is turquoise. So what does it mean in this case?
One interpretation: as the number of rolls becomes large, the expected total approaches the number of rolls times the mean.
Colors aren't cardinal, so you can't give a mean. They also aren't ordinal, so you can't give a median. But you can give a mode, unhelpful as it may be in this case.
That's a natural hierarchy to me: as you go to less and less ordered sets, you can use fewer and fewer methods.
anirudh215 said:
I know what the definition of a mean is...
To be absolutely clear, what definition are you using?
Good grief. I hardly even remember starting this topic. I don't even know why I started it. I posted it just before going to sleep. But let's continue anyway. I've never heard the terms ordinal and cardinal, so I might learn something new.
@bpet : I am using the definition [tex]\overline{x}[/tex] = [tex]\sum x_{i}p(x)[/tex] where the xi are the realizations of a random variable X.
So the "mean" is the weighted average of the possible values, weighted by their probability.
If you are talking about a discrete problem (as you are since you use sum, not integral), you can think of each possible outcome as having "multiplicity" according to its probability. In that case, the mean is just the arithmetic average of all possible outcomes.
anirudh215 said:
I don't even know why I started it...
Ha, no it was a good question. You're on the right track - a random variable is an abstract object that maps an event space to real numbers and needn't have any physical meaning. For your coloured dice example the events (colours) could all be assigned to zero and the mean would be zero. Take care not to confuse the observed mean (sample mean) with the theoretical mean (expected value). Good luck with your studies!
1. How/ why can you map all the colors to zero?
2. What is observed mean and sample mean? The only mean I know of is the one I posted above and it's analog for the continuous case.
  • · Replies 22 ·
  • · Replies 116 ·
