Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Engineering > General Engineering
Reply
image Polygonal mirror reflection beam Problem Share It Thread Tools Search this Thread image
Old Nov5-09, 03:17 PM                  #1
anita1984
anita1984 is Offline:
Hello forum , i have a spindle motor from an HDD and i pasted to this motor 6 facets polygonal mirror, the problem is that the mirrors are not 100% alignment ( it's hand made) and the laser reflected from this mirrors is doing 6 lines ( where it should be one line if all mirrors are good alignment, all 6 lines should be overlap and we can see one line), what do you recommand me a tric to do it to make lines overlap , or a nice method to make another polygonal more profesional.
every facet has a dimension of 3.5cmx1.9cm
Thank you in advance,
Old Nov5-09, 09:58 PM                  #2
BenchTop
BenchTop is Offline:
Re: Polygonal mirror reflection beam Problem
Here are some thoughts.
The very precisely made polygonal mirrors are salvaged from barcode scanners and available from electronic salvage suppliers.
A jig can be made to resemble a faceting machine (google for a pic).
You would start out with a reasonably true polygon and mount it on a rod parallel to a flat.
Then use a protractor to rotate it precisely.
With a stop to set the height above the flat, you would lower the polygon onto a precut mirror with a drop of epoxy on top at each angle of rotation.
This sets your mirrors at precise angles and parallel to the axis of rotation.
Because distance will amplify inaccuracy, the more precisely you set up your indexing and parallelism the better the result will be.
Old Nov6-09, 07:54 PM                  #3
berkeman
PF Mentor
berkeman's Avatar
berkeman is Offline:
Another alternative would be to make the facets adjustable, with a couple set scrrews and springs or something. If you aren't able to precisely machine the base part (which would take a pretty good CNC mill, I would think), then make one that has a way to adjust the 2-D tilt of each mirror (or at least all but one of the mirrors).
Old Nov8-09, 02:52 PM                  #4
anita1984
Thank you for the ideas , i will try them soon ,
Have a nice day
image image
Reply
Thread Tools
Similar Threads for: Polygonal mirror reflection beam Problem
Thread Thread Starter Forum Replies Last Post
Mirror reflection cookiecrunch9 Classical Physics 3 Jul8-08 02:38 PM
mirror reflection? louie3006 Introductory Physics 1 Apr2-08 06:29 AM
Mirror reflection. PLS help strawberry7 Introductory Physics 1 Apr29-07 11:22 PM
reflection off mirror problem positron Introductory Physics 3 Oct21-05 04:44 PM
Mirror reflection touqra General Physics 3 Oct5-05 12:15 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
