Solving non Homogeneous second order differential equation
The discussion revolves around finding the general solution to the non-homogeneous second-order differential equation y'' + y = sec^3(x). Participants are exploring methods to construct the particular solution after identifying the characteristic equation and the homogeneous solution.
  • Mixed
  • Participants discuss the characteristic equation and its roots, with some confusion regarding the form of the homogeneous solution. There are attempts to suggest forms for the particular solution, including using trigonometric identities and the method of variation of parameters. Questions arise about the appropriateness of certain functions for the particular solution.
The discussion is active, with participants providing different approaches and questioning the validity of certain methods. Some guidance on using variation of parameters has been shared, but there is no consensus on the correctness of the proposed particular solutions.
Participants note the challenge of dealing with the non-homogeneous term sec^3(x) and its implications for finding a suitable particular solution. There is acknowledgment of the limitations of the method of undetermined coefficients in this context.
phil ess
Find the general solution to y'' + y = sec3(x)
Well I can get the characteristic equation:
r2 + 1 = 0
r = +-i
Then the homogeneous solution is yh = C1excos(x) + C2exsin(x)
And I know y = yh + yp
but how do I get yp? I've never dealt with powers of cos, only polynomials and ex, so I am not sure how to construct the particular solution.
Thanks for the help!
I tried a few things but didn't get anywhere. You might try yp = Atan x, or yp = Asec x tan x, and see if they get you anywhere. An identity that will probably be useful is sec2x = tan2x + 1.
First, yes, the characteristic equation is [itex]r^2+ 1= 0[/itex] which has roots i and -i. That does NOT mean [itex]y(x)= C_1e^x cos(x)+ C_2e^x sin(x)[/itex]. That would correspond to roots 1+ i and 1- i. The general solution to the associated homogeneous equation is [itex]y(x)= C_1 cos(x)+ C_2 sin(x)[/itex]
Since "sec(x)" is NOT one of the functions that forms solutions for homogeneous linear equations with constant coefficients (polynomials, exponentials, sine and cosine, and combinations of those), there will be no simple way to use "undetermined coefficients".
But you can use "variation of parameters". Look for a solution of the form y(x)= u(x)cos(x)+ v(x)sin(x) where u(x) and v(x) are unknown functions. Notice that we don't need any special knowledge here. Given any solution, y, we could create many functions "u" and "v" that would work. From y= ucos(x)+ vsin(x), y'= u' cos(x)- u sin(x)+ v' sin(x)+ v cos(x). Because there are, as I said, many different function u and v we can simplify our "search" by also requiring that u' cos(x)+ v' sin(x)= 0. With that condition, y'= -u sin(x)+ v cos(x) and then y"= -u' sin(x)- u cos(x)+ v' cos(x)- v sin(x).
Putting those into y"+ y= sec3(x) we have (-u' sin(x)- u cos(x)+ v' cos(x)- v sin(x))+ (u cos(x)+ v sin(x))= -u' sin(x)+ v' cos(x)= sec3(x).
That, -u' sin(x)+ v'cos(x)= sec3(x), and u' cos(x)+ v' sin(x)= 0 give two equations that can be treated as ordinary algebraic equations to be solved for u' and v'. Then integrate to find u and v.
Yeah sorry I realize ex shouldn't be there.
Your stuff was a little hard to follow so I researched the variation of parameters method a little and found basically this:
since W() = 1 I get
[tex]yp = -y1 \int sin(x)sec\stackrel{3}{}(x) dx + y2 \int sec\stackrel{2}{} dx[/tex]
Where y1 = c1cos(x) and y2 = C2sin(x)
And then after some math I get
[tex]yp = \frac{C\stackrel{}{2}sin\stackrel{2}{}(x) - C\stackrel{}{1}}{cos(x)}[/tex] ?
Does this look correct?
