Firework Explosion Homework: Determine Unknown Quantity
  • Thread starter Thread starter shootingrubbe
    Explosion
The problem involves analyzing the explosion of a fireworks device that breaks into three components, with the goal of determining an unknown quantity related to the motion of these components. The subject area includes concepts of momentum and kinetic energy in the context of an explosion.
  • Participants discuss the conservation of momentum as a key principle, with one suggesting that the third component's momentum can be derived from the first two components' momentum. There is also a question about the necessity of knowing the mass of the third component to solve the problem.
The discussion is ongoing, with participants exploring different interpretations of the problem and questioning the assumptions regarding the mass of the components. Some guidance has been offered regarding the use of momentum equations, but no consensus has been reached on how to proceed without additional information.
Participants note the absence of the mass of the third component as a potential constraint in solving the problem, raising questions about how to approach the solution without this information.
shootingrubbe
During testing of a fireworks device an engineer records that data shown in the table below when the device, initially at rest, explodes under controlled conditions into three components that spread out horizontally. Determine the unknown quantity.
http://img687.imageshack.us/img687/8969/screenshot20091105atnov.th.png
No idea how to attempt this at all.
I am thinking that you use the momentum equation:
m1v1 +m2v2 = m1v1' +m2v2'
And potentially the kinetic energy equation (if it's elastic):
0.5m1v1^2 +0.5m2v2^2 = 0.5m1v1'^2 +0.5m2v2'^2
I have no idea where to start. If you could help that would be great.
Thanks.
If it's an explosion then by definition momentum is conserved...
parts 1 and 2 look like they're traveling north and east respectively so therefore in order to conserve momentum the 3rd part should travel southwest! So using the momentum of parts 1 and 2 as the opposite and adjacent parts of a triangle, you should be able to find the hypotenuse = momentum of part 3.
Then p=mv, right, so you can find the velocity of part 3 from there!
Now, would it be possible to solve this problem if they did not give the mass of the 3rd component (flying piece), if so, how?
Thanks.
If you use momentum p=mv to solve it, no, not unless they gave you the original mass of the device and then you just minused off the masses of the other parts to get your 3rd mass.
Unless there's another way you can solve it?
  • · Replies 19 ·
  • · Replies 19 ·
