Electric Field inside a Hollow non conducting sphere.
The discussion focuses on calculating the electric field inside a hollow non-conducting spherical shell with inner radius R and outer radius 2R. Using Gauss's Law, the electric field at the outer surface is derived as E = q/(16π(2R)^2). The charge density is determined to be 3q/(28πR^3). The challenge lies in finding the electric field strength at a radial depth x beneath the outer surface, where R < x < 2R, and determining the total charge contained within the Gaussian surface at that radius.
  • Understanding of Gauss's Law
  • Familiarity with electric field concepts
  • Knowledge of spherical coordinates
  • Basic calculus for integration
  • Study the application of Gauss's Law in different geometries
  • Learn about electric field calculations in non-conducting materials
  • Explore charge density and its implications in electrostatics
  • Investigate the concept of Gaussian surfaces and their significance in electrostatics
Students studying electromagnetism, physics educators, and anyone interested in advanced electrostatics concepts.
sl33py.
Positive charge is distributed throughout a non-conducting spherical shell of inner radius R and outer radius 2R at what radial depth beneath the outer surface the electric field strength is on half to the elextirc field at the surface
Gauss's Law:
integral ( E.dA ) = q/e0
suppose that a charge 'q' is distributed in the sphere then
The electric field at the outer surface will be :
int ( E.dA ) = q/e0
=> E. 4.pi.(2R)^2 = q/e0
=> 16E.pi.r^2 = q/e0
The volume of tht sphere will be :
4/3.pi. (2R)^3- 4/3.pi.R^3
=> 28/3.piR^3
So the charge density will be:
density= charge/volume
p=3q/(28.pi.R^3)
Now imagine a gaussian surface having a radial depth from the outer surface "x", the radial distance for that surface will be 2R-x
i am stuck after that, help would be appreciated
So what's the field at the surface? (In terms of q and R.)
Use the same thinking to find the field at r = X, where R<X<2R. What's the total charge contained in the gaussian surface at r = X?
  • · Replies 18 ·
