How Do You Solve f(x-y) - f(x) in Algebra II?
  • Thread starter Thread starter DukeGuy123
    Algebra
The discussion revolves around a problem in Algebra II involving the function f(x) = x² and the expression f(x-y) - f(x). Participants are exploring how to manipulate and simplify this expression without arriving at a final answer.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to expand and simplify the expression (x-y)² - x². Some express confusion about the steps involved and seek clarification on how to approach the problem.
There is ongoing dialogue with participants offering suggestions on how to expand the expression and questioning the validity of certain answer choices. Some participants are seeking more detailed explanations and step-by-step guidance.
Participants note that the problem is part of a multiple-choice question, which adds a layer of complexity as they attempt to match their results to the provided options. There is also mention of forum policies regarding the provision of complete solutions.
DukeGuy123
I've got a question maybe you guys can answer.
I'm in Algebra II and I was given a question that was worded like this:
"If f(x) = x², then find f(x-y)-f(x)."
Can someone help me? I don't really know how to solve it...
-DukeGuy123
f(x-y)-f(x)=(x-y)^2-x^2
one would then likely be expected to expand and simplify
That's not one of the valid answer choices...
It's one of these four (it's multiple choice):
A) 2x
B) x²-2xy+y²
C) -2xy+y²
D) 2xy-y²
Thanks for your help, but I would like to get an answer that is Correct and WITH WORK.
I really don't know how to solve this.
lurflurf, did you check the answer choices?
Which answer choice would that be? And is there a more detailed way you can explain it, because I still don't get it.
Can you show it like step-by-step or something?
so f(x) = x² means that whenever you see f(*) were * is some expresion you replace it by *2
so if you have
f(x-y)-f(x)
it gives
(x-y)2-x2
you should be able to expand (x-y)2 using foil or (a+b)2=a2+2 a b+y2
then cancel
so if you have
f(x-y)-f(x)
it gives
(x-y)2-x2
then cancel
yup! f(x) =x2 shows you how the function is affecting the variable
if the variable inside the parentheses is something other than x, it is affected the same way that x would be as long as the function is still f, and not some other function.
Anakin_k, it is against the policy in this forum to provide complete solutions to a poster's problems.
Lurflurf Suggested you expand (x-y)2- x2. Have you done that yet?
in case you didnt know (x-y)^2 is really (x-y)(x-y)
with that knowledge you should be able to solve (x-y)(x-y) -x^2 just foil it all out!
(x^2-xy-xy+y^2)-x^2
combine like terms (x^2-2xy-y^2)-x^2
the x'2s cancel oiut leaving you with -2xy-y^2
factor out a -y -y(2x+y)
if i didnt totally screw this up there's your answer.
the pro said:
ah ok hear x2(x-y)-x2(x)-------x3-xy-x3=xy
you don't multiply x-y times x squared. x-y IS x in this problem times the whole thing squared. that's what f(x)=x^2 is saying. its defining the function/ you did not substitute for x you just multiplied numbers by sx.
  • · Replies 19 ·
  • · Replies 23 ·
