Thread Closed
calculating optical power output
Share Thread
Nov10-09, 08:42 AM   #1
A blue semicon LED is connected in series with a 10ohm series resistor to a voltage source. The LED emits 4.03 x 10^16 photons/s at a wavelength of 400nm. The current flowing through the LED is 40mA and the voltage across the LED is 3.5V. Calculate the power conversion efficiency of the diode.
2. Relevant equations
Given,
Conversion efficiency = (optical output power / electrical input power) x 100%
electrical input power = IV (LED) + IV(resistor)
3. The attempt at a solution
Calculated IV for LED = 40x10^-3 x 3.5 = 0.14W
IV for resistor = (40x10^-3)^2 x 10 = 0.016W
so, electrical input power = 0.156W
Having trouble with finding the optical output power. I guess that it got to do with the LED emission and wavelength?
Does anyone know what is the formula for calculating the optical output power? I could not find the formula in any resources on hand. Thanks a million.
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Nov10-09, 01:56 PM   #2
Mentor
Quote by snoothie View Post
Given,
Not sure they want you to inculde the power lost in the series limiting diode in the LED efficiency calculation, but that's up to you.
On the optical power, I'd start with the equation E=hf, where f is the frequency of the photon (often written as the greek character "nu"). Are you familiar with this equation? From that, you calculate the total power as the flux of however many photons per second, each having that energy E=hf.
Nov10-09, 06:18 PM   #3
Ok. thanks for the leads.
we can use:
E = hc/e.wavelength
then, the flux is simply: Eph x photons/s, which also is the optical output power in watts?
Nov10-09, 06:24 PM   #4
Mentor
we can use:
E = hc/e.wavelength
Don't know what e.wavelength is, but it looks like you are on the right track.
Nov10-09, 06:39 PM   #5
oh sorry. My bad...
I was refering it as:
Eph = (hc/e) x wavelength
e = 1.6 x 10^-19 eV
Thank you very much for your help.
Thread Closed
Similar discussions for: calculating optical power output
Thread Forum Replies
A question about DC motor (input power, output power) General Physics 3
Steps for calculating dc generator output potential Electrical Engineering 2
Solar Cell calculating the power output Introductory Physics Homework 2
Calculating synchronous motor output power Electrical Engineering 0
Calculating output force of wind funnel Mechanical Engineering 2
