Calculate RPM: Kinetic Energy of a Wheel with Mass 15kg and Diameter 1.2m
  • Thread starter Thread starter Kev1n
    Rpm
The discussion focuses on calculating the RPM of a wheel with a mass of 15 kg and a diameter of 1.2 m to determine its kinetic energy. The moment of inertia (I) is calculated using the formula I = mk², resulting in I = 2.4 kg·m². The kinetic energy (KE) is derived from the equation KE = 0.5 Iω², where ω is the angular velocity in radians per second. The relationship between RPM and angular velocity is established as ω = RPM × 2π/60, allowing for the conversion needed to find the RPM.
  • Understanding of rotational dynamics and moment of inertia
  • Familiarity with kinetic energy equations in physics
  • Knowledge of angular velocity and its relationship to RPM
  • Basic algebra for manipulating equations
  • Study the relationship between linear velocity and angular velocity in rolling objects
  • Learn how to derive and manipulate the kinetic energy formulas for different shapes
  • Explore the concept of radius of gyration and its applications in rotational motion
  • Investigate the effects of mass distribution on moment of inertia for various geometries
Students and professionals in physics, mechanical engineering, and anyone involved in the analysis of rotational motion and energy calculations.
Kev1n
1. I need to find out the kinetic energy of a wheel, mass 15kg, diameter 1.2m, radius of gyration 0.4m traveling at 4ms. To do this I need to find RPM
2. Kinetic Energy = 0.5 Iw^2, I = mk^2
3. I = 15 x 0.4^2 = 15 x 0.16 =2.4kgm^2
KE = 0.5 x 2.4 x w^2
W = rpm x 2pi/60
How can I find rpm
Hi Kev1n! :smile:
(have an omega: ω and try using the X2 tag just above the Reply box :wink:)
How can I find rpm
Is this a rolling wheel?
If so, it will have both rotational kinetic energy and ordinary kinetic energy.
And the speed is 4 m/s, and the diameter is 1.2m, so how far does the wheel move when it goes round one revolution? :smile:
