How Does Temperature Affect the Heat Capacity of a Rubber Band?
The discussion focuses on the relationship between temperature and the heat capacity of a rubber band, described by the equation of state L = f(b/T). Participants derive the change in constant-length heat capacity (CL) with respect to length (L) at constant temperature (T) using Maxwell's relations. The key conclusion is that (δCL/δL)T equals f/T - 1, indicating a direct dependency on the rubber band's tension and temperature. The conversation also addresses the implications of these findings on the behavior of the rubber band under varying thermal conditions.
  • Understanding of thermodynamic principles, specifically Maxwell's relations.
  • Familiarity with the concepts of entropy (S) and heat capacity (CL).
  • Knowledge of calculus, particularly partial derivatives and chain rule applications.
  • Basic grasp of the physical properties of materials, particularly elasticity and thermal behavior.
  • Explore the derivation and applications of Maxwell's relations in thermodynamics.
  • Study the relationship between entropy and heat capacity in various materials.
  • Investigate the effects of temperature on the mechanical properties of elastomers.
  • Learn about the implications of thermal expansion and contraction in rubber-like materials.
Students and professionals in physics and materials science, particularly those studying thermodynamics, rubber elasticity, and heat capacity behaviors in materials.
llabesab16
1. The problem: Suppose a rubber band obeys the equation of state: L = f (b/T), where L is length, f is tension, b is a constant, and T is temperature. For this rubber band, determine (δCL/δL)T, i.e. the change in the constant length heat capacity with length at constant temperature. You should be able to determine this using the following Maxwell Relation: (δf/δT)L = - (δS/δL)T, where S is the entropy
2. equations: dS = [(δS/δL)T]dL + [(δS/δT)L]dT
The constant length heat capacity, CL = T[(δS/δT)L]
3. Attempt: since L = f (b/T), TL = fb, and d(TL) = d(fb). b is constant, and hold L constant and use chain rule to get LdT = bdf. This implies that (δf/δT)L = L/b. Using the Maxwell relation, this implies that L/b = - (δS/δL)T. Also, using the equation of state, L/b = f/T, so - (δS/δL)T = f/T also. As mentioned above, dS = [(δS/δL)T]dL + [(δS/δT)L]dT. [(δS/δL)T] = - f/T, and [(δS/δT)L] is the constant length heat capacity divided by T, [CL]/T. Since dS is an exact differential, another Maxwell relation results from this: [(δ[[CL]/T]/δL)T] = -[(δ(f/T)/δT)L]. Using the chain rule, I got that (δCL/δL)T = f/T - 1
I hope this is clear enough. Let me know if I need to clarify anything. Second opinions would be greatly appreciated! Thanks
Isn't
[tex]-\left(\frac{\partial(f/T)}{\partial T}\right)_L=-\left(\frac{\partial(L/b)}{\partial T}\right)_L[/tex]
equal to zero? And since you have this as equal to
[tex]\left(\frac{\partial(C_L/T)}{\partial L}\right)_T=\frac{1}{T}\left(\frac{\partial C_L}{\partial L}\right)_T[/tex]
would the change in the constant-length heat capacity with length at constant temperature also be zero?
9K
