Brine Tank Optimization Problem
The problem involves a brine tank initially filled with a specific concentration of salt, where fresh brine with a different concentration is added and the mixture is drained at the same rate. The goal is to model the change in the amount of salt in the tank over time using a differential equation.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the formulation of a differential equation to model the salt concentration dynamics, questioning the initial conditions and the rates of salt entering and leaving the tank.
Some participants have provided guidance on how to express the rates of salt entering and leaving the tank, while others are seeking clarification on the setup of the equation. There is an ongoing exploration of the assumptions and definitions involved in the problem.
There is a discrepancy regarding the initial amount of salt in the tank and the interpretation of the problem as an optimization task. Participants are addressing these assumptions and clarifying the requirements of the problem.
tornzaer
A tank is initially filled with 1000 litres of brine, containing 0.15 kg of salt per litre. Fresh brine containing 0.25 kg of salt per litre runs into the tank at the rate of 4 litres per second, and the mixture (kept uniform by stirring) runs out at the same rate. Show that if Q (in kg) is the amount of salt in the tank at the time t (in seconds) then d/dt Q(t) = 1 - ((Q(t))/(250))
I know I have to take the derivative since this is an optimization problem and it includes rates, but nothing else.
I know that the there are 1000 litres of brine and 0.15 kg of salt per litre. the 0.15 kg is already in. In addition, 0.25 kg of salt per litre runs into the tank at a rate of 4 litres per second. This is where I'm having trouble. How do I formulate an equation in relation to the one given?
Please help.
Some of what you know is not true. You do not have to take a derivative, nor is this an optimization problem. Your job in this problem is to show that the differential equation dQ/dt = 1 - Q/250 models the situation described in your problem.
Q(t) = quantity of salt in kg at time t.
It is not true that there is .15 kg at time t = 0. You need to write an equation that expresses the amount of salt coming into the tank per minute and the amount going out per second. For example, a brine solution of .25 kg of salt comes into the tank at a rate of 4 liters/sec. This means that salt is coming into the tank at a rate of .25 kg/L*4 L/sec = 1 kg/sec.
Alright. How would I go about setting up the equation then? I'm still not clear on that.
What quantity of salt is coming in per second? What quantity of salt is going out per second. The rate in - the rate out is dQ/dt. If more is coming in than going out, dQ/dt > 0. If more is going out than coming in, dQ/dt < 0.
