Solve for Person's Final Height After Jumping Off Bridge
The problem involves calculating the final height of a person after jumping off a bridge, with a mass of 60 kg and a bridge height of 60m. The cord begins to stretch after a 20m fall, with a spring constant (k) of 50 N/m. The initial energy equation mgh = (1/2)kx² was correctly set up, yielding a stretch distance (x) of 38m, resulting in a total fall distance of 58m from the bridge. For the second part, the equilibrium condition ΣFy=0 must be applied to determine the final height above the water when the person comes to rest.
  • Understanding of gravitational potential energy (mgh)
  • Familiarity with elastic potential energy ((1/2)kx²)
  • Knowledge of spring constants and their application in physics
  • Basic principles of conservation of energy
  • Review the concept of conservation of energy in mechanical systems
  • Study the effects of air resistance on oscillating objects
  • Learn about the dynamics of springs and Hooke's Law
  • Explore equilibrium conditions in static systems
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for examples of real-world applications of these concepts.
Illyasviel
Mass of person jumping off bridge = 60 kg
The bridge is 60m above the river
The cord only starts stretching after he falls 20m.
k = 50 N/m
gravitational potential energy = mgh
elastic potential energy = (1/2)kx^2
So this problem is asking how far below the bridge the person will fall before coming to a stop (before he bounces back up).
I did mgh = (1/2)kx^2 which is 36000J = (1/2)(50)(x^2) and got x = 38m. Can someone verify whether this is right? (As in did I set up the problem properly).
But my real question is for the second part. He bounces up and down a few times but eventually due to air friction he hangs at rest. At what height above the water is he then?
I'm not sure what I'm supposed to do exactly do to find this. Can someone offer hints?
I see your mistake at the first part. What is x and what is h?
X is not counted from the bridge. x is the distance from the neutral position of the spring. You use it like it s the distance from the bridge. You can either use the Conservation of Energy at h=40m ( when the spring starts stretching ) or the way you do it you must define your x differently. Your x there must be something like (distance from bridge) = 20+x where x is the distance from the neutral position of the spring. so the x you find must put it in this equation and distance= 20 + 38= 58meters from the bridge.
For the second part ( which is much much easier ) you need Only to think what happens when the man remains still. ΣFy=0
  • · Replies 26 ·
