Bouyant force on a cube floating at the surface between water and oil?
A cube with a side length of 15 cm is floating at the interface of water and oil, with the oil density at 810 kg/m³. The cube is 52% submerged in water and 48% in oil. Using Archimedes' Principle, the buoyant force (Fb) is calculated as 30 N, leading to a mass of the cube determined to be 3.33 kg. This analysis demonstrates the application of fluid mechanics principles to calculate buoyancy in a multi-fluid system.
  • Understanding of Archimedes' Principle
  • Knowledge of fluid density calculations
  • Basic algebra for solving equations
  • Familiarity with gravitational force (g = 9.8 m/s²)
  • Explore advanced applications of Archimedes' Principle in various fluid systems
  • Learn about the effects of fluid density on buoyancy in different materials
  • Investigate the calculation of buoyant forces in irregularly shaped objects
  • Study the principles of hydrostatics and their applications in engineering
Students studying physics, engineers working with fluid dynamics, and anyone interested in understanding buoyancy and fluid mechanics principles.
kalisious
A cube of 15 cm is floating at the surface between water and oil. The oil has a density of 810 kg/m3. If the cube floats so that it is 52% in water and 48% in the oil, what is the mass of the cube and what is the buoyant force on the cube?
Archimede's Principle
Fb= densityfluidvfluidg
Not sure how to find the mass of the cube when only the height of one side is given?
The cube is displacing it's own weight in oil and water.
it might be simpler to think of it as two (almost ie 0.52/0.48) half cubes immersed in oil and water.
fb = (1000*0.52+810*0.48)*0.15^3*9.8
=30 N
mass=fb/g
=30/9=3.33
