Originally Posted by JANm
If you take the distance of the moon d_ME= 1 1/3 lightsecond, then I think there is enough data to calculate the moon-o-statical orbit.
A rope shorter than the ...-o-statical orbit moves to slow to leave it upright, yet a rope reaching beyond the o-statical orbit moves fast enough to centrifugate more than then the gravitational pull. I am still not certain what would become the shape of a rope let us say twice as large as the moon-o-statical orbit...
greetings JanM
The moon rotates too slowly for a traditional! space elevator to work. However, a rope through either the L1 or L3
Lagrange point is quite practical. Since the rope/beanstalk/skyhook would be much shorter than on Earth, and subject to 1/6 the gravity, even more conventional materials than carbon nanotubes can be used. For example, such a space elevator made of Kevlar would only take a few shuttle loads to set up.
The two tricky parts are the moon's libration, and that its orbit around the earth is elliptical. For a skyhook through the L1 point, the latter can be dealt with by making it longer than necessary and anchoring it well on the moon's surface. But this is where the libration comes in. Since the moon has libration in both latitude and longitude, connecting the beanstalk to a track wouldn't work. Besides, the track would take a lot more construction materials, and work, than the beanstalk itself. A simple solution is to use the beanstalk to lift the anchor on the moon, use the pendulum effect to sway the anchor past the sub-Earth point, then put it down again. Seems complicated, but it is probably the easiest way to make a lunar beanstalk work.
Note also that any plans for visiting Mars
without setting up a beanstalk are silly. The weight of cable needed is small compared to any Mars lander/orbiter, and Deimos provides a useful anchor. Again, a beanstalk dropped from Deimos, would not remain above any particular point on the Martian surface. For exploring, this is good--you can drop exploration teams anywhere along the Martian equator and recover them a few days later.
