Calculate Momentum & Impulse for Mass 0.25kg, Speed 15m/s
  • Thread starter Thread starter Physicshelpneeded
    Impulse Momentum
The discussion revolves around calculating momentum and impulse for a ball with a mass of 0.25 kg moving downward at a speed of 15 m/s. The problem involves determining the net impulse exerted by a hand to bring the ball to rest over a time interval of 0.15 seconds, as well as the average force applied during this process.
  • Participants explore the relationship between impulse and time, with some questioning the relevance of time in calculating impulse. There are discussions about the equations used for impulse and force, with varying interpretations of how to apply them.
Participants are actively engaging with the problem, offering different perspectives on the calculations and questioning the phrasing of the problem. Some have provided calculations, while others express confusion about the role of time in the impulse calculation. There is no explicit consensus, but several participants have acknowledged the need to clarify the definitions and relationships involved.
Some participants note that the problem may be a "trick question," leading to discussions about the implications of confidence in problem-solving versus actual understanding. There are also concerns about how the downward motion of the ball affects the direction of the forces involved.
Physicshelpneeded
This question kinda stumped me :frown: ...
Suppose that a ball of mass 0.25 Kg is moving downward at a speed of 15 m/s when it lands in your hand.
(a) If it takes .15 s to bring it to rest in your hand, what is the net impulse your hand exerts on the ball to bring it to rest? Give both size and direction
What i did for this problem was F = M (V<f> - V<i>) / Time
.......OR F = -25N (when u solve it like i did)
i was thinking if impulse is in units N.S or Kg m/s - then this stuff that i did is incorrect...is the equation I am using wrong? because i have different equations but this is the only one that encompasses all information given in the question.
part b asks: what is the average net force u exerted on the ball to stop it? Give both size and direction...for this i used F = m x a
........OR F = 3.75 N when i solved...
this seems to easy, did i do something wrong? or is it correct?
Thanx
(a) is poorly stated, in the sense that the impulse is independent of the time spent
(It is simply M(vf-vi))
(b) Assuming you did the correct algebra, the average F is 25N in the upwards direction (Simply, impulse divided with time)
I suspect it is something of a trick question, which is why it is stated that way. To test if the reader really knows what is meant by impulse. But in any case, your answer is the correct one.
Might well be, Tyger.
However, this is the type of "trick questioning" that I dislike the most:
It does not necessarily measure what a person knows, but the confidence by which someone knows it
That is, breezily confident individuals will score high, whereas someone who at times doubt their own competence (which may be higher than the over-confident's) will be thrown in confusion, and enter a wrong answer, against their own, better judgment.
I.e, these types of questions borders on measuring personalities, rather than competence.
if this is true arildno...then my equation is fine as long as i take away the time right? does anyone else know how to do this or help?
and how can the force be +25 N if the ball is traveling downward - therefore acceleration is -10 (gravity on earth) - therefore force should be proportional and also negative...right?
(a)Yes, as I said, the impulse is M(vf-vi)=M(0-vi)=-Mvi, that is, in the opposite direction than the initial velocity of the ball (i.e, upwards)
(b)Your hand exerts an upwards force on the ball.
ok, thanks a lot for ur help guys, but i still don't understand why time is given but cannot be used.
but maybe it IS a trick question and it is put there for that reason.
-Thanks again,
Arabian Knight (Sari)
The time is used in (b) and not in (a)
m(v - u)
F = ....
t
is how you figure out impulse
or Ft = mv - mu
so I'm not sure how f= mv-mu can be correct...
I = MV-MU
I = 0-(0.25x15)
I = 3.75 NS acting upwards.
I = 3.75 = Force x time
I now presume it means the 'average force'. Net impulse is a pointless term when working in 2D here and they wouldn't give you the time for nothing.
3.75 = .15 x force.
3.75/.15 = Force
Average force exerted = 25N
Obviously the force is upwards, as it has stopped the downwards motion.
  • · Replies 19 ·
9K
  • · Replies 24 ·
