Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Ducted fan intake Share It Thread Tools Search this Thread image
Old Nov15-09, 11:44 PM                  #1
JD88
JD88 is Offline:
Ducted fan intake
Would the performance of a ducted fan be negatively affected by the presence of a surface flush with the intake of the fan?
Old Nov16-09, 12:49 AM                  #2
russ_watters
PF Mentor
russ_watters is Offline:
Re: Ducted fan intake
Um...it sounds like you are asking if the performance of a ducted fan would be negatively affected by blocking the inlet. How could it not be?
Old Nov16-09, 08:07 AM                  #3
minger
minger is Offline:
Recognitions:
Sure any discontinuities or irregularities will negatively affect the performance. What do you mean exactly be surface flush? Like two surfaces not sharing the same centerline?
Old Nov16-09, 08:14 AM                  #4
JD88
JD88 is Offline:
I have a surface with a hole cut in it that is the diameter of the fan. The fan is then placed in this hole so that the surface and the inlet of the fan are in the same plane.
Old Nov16-09, 11:54 AM                  #5
Q_Goest
Q_Goest's Avatar
Q_Goest is Offline:
Recognitions:
PF Contributor PF Contributor
Homework Helper Homework Helper
Yes, the performance (flow and/or pressure) will be negatively affected. A well rounded entrance is best to provide a smooth flow of air into a fan. A quantitative difference would need to look at the fan's actual operating point. Do you need to actually determine the operating point of the fan or are you just asking qualitatively if the fan's performance will be adversely affected?
Old Nov16-09, 05:26 PM                  #6
JD88
JD88 is Offline:
Just qualitatively.
My fan is currently hooked up to a force balance to measure thrust, and I was concerned that this situation may not accurately reflect how the fan will perform.
Old Nov16-09, 08:54 PM                  #7
FredGarvin
FredGarvin's Avatar
FredGarvin is Offline:
Recognitions:
It will allow it to perform just not as well as it could. This is why there is a lot of design and analysis work that goes into things like nacelles and inlets on aircraft.
image image
Reply
Thread Tools
Similar Threads for: Ducted fan intake
Thread Thread Starter Forum Replies Last Post
Electric Jet Ducted Fan? violin_writer Aerospace Engineering 38 Jan17-10 12:15 PM
The Cold Jet (ducted fan/propeller) kach22i Mechanical Engineering 15 Nov1-09 01:09 PM
Ducted fan project JD88 General Engineering 13 Aug30-09 07:32 PM
Ducted Fan Thrust krisd Mechanical Engineering 2 Apr20-08 11:56 PM
Ducted Fan Propulsor/Generator Turbofrog Mechanical Engineering 2 Nov25-07 02:43 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
