What Equation Do You Use to Calculate Average Net Force on a Bouncing Superball?
  • Thread starter Thread starter Physicshelpneeded
    Formula Momentum
The discussion centers around calculating the average net force exerted on a superball during its collision with a table. The problem involves concepts from mechanics, specifically momentum and force, as the superball bounces back after hitting the table.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the correct interpretation of the time unit "ms" and its conversion to seconds. There is also a debate about the mass of the superball, with some questioning the realism of the given mass values. Various calculations for average net force are proposed, with differing results based on unit conversions and assumptions about the initial and final velocities.
The conversation is ongoing, with participants providing clarifications on unit conversions and raising questions about the accuracy of the mass used in calculations. Some guidance on ensuring consistent units in calculations has been offered, but no consensus on the correct force value has been reached.
There is confusion regarding the correct interpretation of time in milliseconds and its conversion to seconds, which affects the calculations. Additionally, the mass of the superball is debated, impacting the overall understanding of the problem setup.
Physicshelpneeded
hey again all!
When given the following information, what equation do you use to solve this and should the answer be around .02 N?
A superball (very bouncy) of mass .05 Kg is dropped onto a table top. Its speed as it hits the table top is 6.0 m/s. It bounces off the table and rises to the same height from which it fell. If the superball was in contact with the table for 30 ms (What is ms? is it a typo? i had trouble figuring that out too), calculate the average net force (magnitude and direction) exerted on the ball during its collision with the table. Show your work. (hint: calculate the change in momentum caused by its collision with the table.)
For this problem, i said (with the given values):
F = 0.5 Kg (6.0 - 6.0) / 30 ms? F = 0.02 N
Is this correct? is it even int he right ballpark? Please help me and leave me any advice you can :redface:
Thank you
Okay, first "ms" is milliseconds or [tex]10^{-3}[/tex] seconds.
Then I think you mean to say F = 0.5 Kg (6.0 - (-6.0))m/s / 30 ms .
This is correct, and should give you the answer F = 200 N
0.5 or 0.05? A 0.5 kg superball is unrealistic. A 0.05 kg superball is a little more realistic, but still too small since that is the mass of only five Cheez-It crackers (which are scientifically manufactured to produce masses of EXACTLY one gram each).
hey, you must be in my physics class cause we have the same homework questions! Anyways, i got 2N because 30 milliseconds is .3 of a second. so you have to divide it by .3 instead of 30.
30 milliseconds is 0.03 seconds.
uh oh... then what is 1 of those things on the stopwatch?
centiseconds ?
Princexcharles...1000 ms is equal to 1 second...so 30 ms would be 0.03 seconds.
Also, Physicsneededhelp...for future reference, make sure you check your units before you go through with your calculations. In your earlier post, you were dividing meters/seconds by miliseconds...make sure all your units are the same (i.e...in the case of the problem above, because velocity was expressed in m/seconds...your time should also be expressed in seconds.) Keep this in mind, and it should make everything a lot easier! :-D
what's a "short circuit"? (general physics, please help!)
I am currently reading electricity and although I have read my textbooks well, I still don't understand what a "short circuit" is..thanks
How did this get into a thread on "Formula equations and momentum!"?
(As a matter of courtesy- start your own thread, don't hijack others.)
A "short circuit" is exactly what it says: two of the wires accidently cross so that the circuit is shorter than it should be (imagine a circle squeezed into a figure 8).
18K
