| Thread Closed |
Find the equation of the plane which contains the point (3,2,-3) and the line (x,y,z) |
Share Thread | Thread Tools |
| Nov17-09, 09:11 PM | #1 |
Find the equation of the plane which contains the point (3,2,-3) and the line: (x,y,z) = (7,-4,5) + t (0,-2,2) 2. Relevant equations Point-Normal equation? a(x-x0)+b(y-y0)+c(z-z0) = 0 Not sure if this is related. 3. The attempt at a solution First off: The line (xyz) should be (7,-4,5) + t (0,-2,2) which becomes (7, -4-2t, 5 +7t). And then yea... I'm behind :(. I've been sick for the past 2 weeks and I don't understand my friends' notes. So I'm not asking for any of you to solve this for me, but if someone could point me in the right direction and help me on interpreting the question, then that would be great. Thanks. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Nov17-09, 09:18 PM | #2 |
Recognitions:
You can use the normal equation once you find a normal. You've got one direction vector which is parallel to the plane which is the direction vector to the line. Find another one by taking the difference between your point and any point on the line. Then use the cross product.
| Nov17-09, 09:20 PM | #3 |
Or- just take two different values of t to find two different points on the line. You now have three points in the plane. You know how to find the plane containing three given points, don't you?
| Nov17-09, 10:04 PM | #4 |
Find the equation of the plane which contains the point (3,2,-3) and the line (x,y,z)ax + by + cz + d = 0 to get the equation of each point and solve for the system of equations? Is there a difference between "passing through the points" and "contains the points" in terms of planes? |
| Nov17-09, 10:14 PM | #5 |
Recognitions:
| Nov18-09, 05:22 AM | #6 |
But the way most people learn to find the plane containing three given points is to determine the vectors from one of the points to the other two and take the cross product of those- which leads back to the method Dick is suggesting. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Find the equation of the plane which contains the point (3,2,-3) and the line (x,y,z)
| Find the point of intersection of the plane and line. Determine if line lies in plane | Calculus & Beyond Homework | 5 | ||
| Find Equation of Plane perpendicular to line passing through a point | Calculus & Beyond Homework | 9 | ||
| Find point where line intersects plane | Calculus & Beyond Homework | 2 | ||
| Find Cartesian equation of plane containging line with parametric equations and point | Precalculus Mathematics Homework | 3 | ||
| Find point of intersection of a line and a plane | Precalculus Mathematics Homework | 2 | ||
