Understanding Factor Groups of Infinite Groups: Examples and Solutions
  • Thread starter Thread starter Newtime
    Group
The discussion focuses on understanding factor groups of infinite groups, particularly through examples from "A First Course in Abstract Algebra." The user expresses confusion about the classification of factor groups, specifically regarding (Z x Z x Z) / <(1,1,1)> and (Z x Z) / <(2,2)>, questioning why certain elements can be unique in cosets while others cannot. They explore the reasoning behind the isomorphisms presented in the book, noting that their logic feels insufficient for deriving the answers independently. A proposed method involves recognizing the structure of subgroups and applying knowledge of direct products and quotient groups to clarify the classifications. Overall, the conversation highlights the complexities of factor groups in infinite groups and seeks clearer explanations for their classifications.
Newtime
For those of you with "A First Course in Abstract Algebra 7th ed.," I'm on chapter 15 and in particular, the first 12 questions. Basically, I understand very well how to classify any factor groups of finite groups, but it's these factor groups of infinite groups that just seem so arbitrarily classified. Here's a few examples that exemplify my problem:
8. (Z x Z x Z) / <(1,1,1)>. That is, Z x Z x Z "over" the subgroups generated by (1,1,1). Now the answer according to the book is that this factor group is isomorphic to Z x Z since every coset of the factor group contains a unique element of the form (0,m,n) where m and n are integers. This reasoning makes sense but then why can't I use the same reasoning and say that each coset also has a unique element of the form (0,0,m) or (m,n,q) thus making the factor group isomorphic to Z or Z x Z x Z respectively?
11. (Z x Z) / <(2,2)>. According to the book, this factor group is isomorphic to Z2 x Z. If I'm given the answer I can come up with a reason why it's true: the factor group contains an element of order 2 and an element of infinite order... but not only is this logic flimsy at best, I also would have no idea how to come up with the answer in the first place.
12. (Z x Z x Z) / <(3,3,3)> The answer here is Z3 x Z x Z with much of the same logic/problems as number 11. above.
Any help is appreciated, these problems have been bugging me.
Noone?
8.- Let (a,b,c)+H be a coset induced by H:=&lt;(1,1,1)&gt; \subset \mathbb{Z} \times \mathbb{Z} \times \mathbb{Z} we want (0,d,e) \in (a,b,c)+H but this happens iff (0,d,e)-(a,b,c) \in H iff (a,b-d,c-e) \in H so we have b-d=a and c-e=a so taking d=b-a and e=c-a we get our element and the fact that it's unique is rather easy: Assume (0,x,y) +H=(0,z,w)+H then x-z=0=y-w.
Now take (a,b,c)+H we want an element (0,0,d) \in (a,b,c)+H and reasoning as before we have a=b=0, d=c which clearly isn't satisfied by all elements (a,b,c) so not ALL cosets have an element of the form (0,0,d). On the other hand if you want an element (d,e,f) we get a-d=b-e=c-f and we loose the fact that in each coset the element (d,e,f) is unique.
Another way to tackle this problems is to note that &lt;(1,1,1)&gt; \cong \mathbb{Z} \times 0 \times 0 , &lt;(2,2,2)&gt; \cong 2\mathbb{Z} \times 0 and in general &lt;(k,...,k)&gt; \cong k\mathbb{Z} \times 0 \times ... \times 0 (where there are n k's and (n-1) 0's ) and with a little knowledge of direct products and quotient groups you get:
\frac{ \mathbb{Z} ^n }{ k_1\mathbb{Z} \times ... \times k_n\mathbb{Z} } \cong \mathbb{Z} _{k_1} \times ... \times \mathbb{Z} _{k_n}
Thanks, this was quite helpful.
Thread 'How to define a vector field?'
Hello! In one book I saw that function ##V## of 3 variables ##V_x, V_y, V_z## (vector field in 3D) can be decomposed in a Taylor series without higher-order terms (partial derivative of second power and higher) at point ##(0,0,0)## such way: I think so: higher-order terms can be neglected because partial derivative of second power and higher are equal to 0. Is this true? And how to define vector field correctly for this case? (In the book I found nothing and my attempt was wrong...
  • · Replies 26 ·
  • · Replies 17 ·
  • · Replies 21 ·
