Static Triple Vector Load Calculator
The discussion focuses on calculating the load distribution among three lines (A, B, C) connected to a static load (W) in a three-rope system. The user has successfully applied trigonometry for a two-rope system but struggles with the complexity of three vectors in a static equilibrium scenario. The key equations for static equilibrium are established: the sum of the horizontal components (Ai + Bi + Ci = 0) and the vertical component (Ak + Bk + Ck = W). The user seeks assistance in resolving simultaneous vector equations to determine the load on each line.
  • Understanding of static equilibrium in physics
  • Proficiency in vector mathematics
  • Knowledge of trigonometric functions and their applications
  • Familiarity with simultaneous equations
  • Study the principles of static equilibrium in multi-rope systems
  • Learn about vector decomposition and its applications in physics
  • Explore advanced trigonometric techniques for three-dimensional problems
  • Research methods for solving simultaneous equations in vector analysis
Engineers, physicists, and students involved in mechanics, particularly those working with static load systems and vector analysis in three dimensions.
splents
Hi All,
I've been trying to figure out how to get this formula working for a few days now, and I *refuse* to give up.
There are three high points, with a line running down from each to a load W.
Each of the lines A,B,C are at different angles to each other (x-y plane), and each of the lines depart the load to the high points at different angles (z-plane).
The load is static, and there is no stretch or movement in the system.
By knowing only the angles of the lines and the weight of the load, how can I calculate the load on each line?
I have calculated this for a two rope system and it is simple trig, but for a three rope system I cannot seem to get it happening!
I've tried solving using trigonometry, but I keep getting stuck. Today I've been trying to solve simultaneous vectors, but I still can't seem to get it right.
If anyone has any clues, or could help I would greatly appreciate it.
I can also draw up a picture to show the system, if that helps.
Some extra information that I've been trying to use for simultaneously solving is this;
If Vectors:
A=[Ai, Aj, Ak]
B=[Bi, Bj, Bk]
C=[Ci, Cj, Ck]
Then for the system to be static:
Ai + Bi + Ci = 0
Aj + Bj + Cj = 0
Ak + Bk + Ck = W
  • · Replies 22 ·
  • · Replies 16 ·
