Metric Space, closed ball is a closed set. prove this
The discussion revolves around proving that a closed ball in a metric space is a closed set. The context is set within the framework of metric spaces and topological definitions, particularly focusing on limit points and the properties of closed sets.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore various definitions of closed sets, including the requirement to contain limit points and the relationship to open sets. Some express uncertainty about how to approach the proof, while others suggest considering the definitions of limit points and boundary points.
The discussion includes attempts to outline a proof and various suggestions for approaches. Some participants have provided partial reasoning and definitions, while others are still seeking clarity on the concepts involved. There is no explicit consensus, but several lines of reasoning are being explored.
Participants note the importance of definitions in the proof, particularly regarding limit points and boundary points. There is an emphasis on understanding the implications of finite versus infinite sets in the context of closed balls.
Ankit Mishra
Let (X, d) be a metric space. The set Y in X , d(x; y) less than equal to r is called a closed set with radius r centred at point X.
Show that a closed ball is a closed set.
In a topological space, a set is closed if and only if it coincides with its closure. Equivalently, a set is closed if and only if it contains all of its limit points.
I have no idea, please help!
What have you tried? There are a few ways to show a set is closed. You can try showing that it contains all of its limit points, or try showing that the complement is open.
Remember, what is the definition of a limit point? Have you tried using the second definition of a closed set?
Well I wrote that the boundary points in a closed ball are contained, but i don't know how to prove it?
The closed about p, of radius r, is defined as [itex]\{ q| d(p, q)\le r\}[/itex]. What are the boundary points of that set?
Here is my proof. I would appreciate any comments. Assuming it's correct, I like this proof because it doesn't require knowledge of sequences.
Let B[x0,ε] be the closed ball.
We will show that this set contains all of its limit points.
Case 1: |B[x0,ε]| < ∞
A finite set contains all of its limit points.
Case 2: Otherwise
Let x' be a limit point of B[x0,ε]. W.t.s. x' is in B[x0,ε].
Suppose x' is not in B[x0,ε]. Then d(x0,x') > ε.
Let γ = 1/2 * (d(x0,x')-ε). Then γ > 0.
Consider the open set B(x',γ). Since x' is a limit point of B[x0,ε], (B(x',γ) intersect B[x0,ε]) - {x'} ≠ null set.
Let a be an element of (B(x',γ) intersect B[x0,ε]) - {x'}.
By definition, d(x0,x') = ε + 2γ.
d(x0,a) + d(x',a) < ε + γ < ε + 2γ = d(x0,x').
By the triangle inequality, d(x0,x') < d(x0,a) + d(x',a).
This is a contradiction.
In all cases, x' is an element of B[x0,ε].
Since B[x0,ε] contains all of its limit points, it is a closed set.
  • · Replies 19 ·
