Did I Solve This Work with Variable Force Problem Correctly?
The discussion centers on a problem from "Calculus and Analytic Geometry" by George B. Thomas, where a particle of mass m is moved against a variable force F(t) = t² with constant acceleration a. The user calculated the work done as W = mah + h²/a, while the textbook states the answer is W = 4h/3 √(3mh). The user questions the textbook's result, arguing it does not account for acceleration and that the units do not align. The consensus is that the user’s calculations are correct, and the textbook may contain an error.
  • Understanding of integral calculus, specifically applications of integrals.
  • Familiarity with Newton's laws of motion and concepts of force and acceleration.
  • Knowledge of variable forces and how they affect work done on an object.
  • Ability to manipulate and solve equations involving force, mass, and acceleration.
  • Review the concept of work done by variable forces in physics.
  • Study the derivation of work formulas in calculus, particularly for variable forces.
  • Examine examples of similar problems in "Calculus and Analytic Geometry" for clarity.
  • Explore the relationship between acceleration, force, and work in classical mechanics.
Students of calculus, physics enthusiasts, and educators seeking to clarify concepts related to work done by variable forces and the application of integrals in real-world scenarios.
suffian
I just did the following textbook problem (from my Calculus book under the chapter review from Applications of Integrals) but came up with an answer that differs from the one at back of the book:
A particle of mass m starts from rest at time t = 0 and is moved along the x-axis with constant acceleration a from x=0 to x=h against a variable force of magnitude F(t)=t2. Find the work done.
Calculus and Analytic Geometry by George. B Thomas
I reasoned as follows:
The force I need to apply at any given time t to maintain constant acceleration would need to be t2 to cancel out the force acting against me plus ma to maintain a constant forward acceleration. In other words F(t) = t2+ma.
If the acceleration is always a and the particle starts from rest at x=0 then
x''(t) = a
x'(t) = at
x(t) = at2/2
This means that once the particle reaches a position x, the following amount of time has elapsed:
t(x) = sqrt(2x/a), t > 0
Which in turn leads to the force that needs to applied at a given position x:
F( sqrt(2x/a) ) = 2x/a + ma
We now use the work formula W= ∫a..b F(x)dx :
W = ∫0..h (2x/a + ma)dx
W = mah + h2/a
On the otherhand, the book gives the following result:
W = 4h/3 sqrt(3mh)
I don't see how they arrived at their results since it doesn't take into account the acceleration of the particle. Surely, the faster the particle is accelerated the work should take toward a limiting value of mah(force * distance) because the particle will reach its destination faster and therefore have less resistance to deal with (remember the resistance was t2). But the book doesn't ever consider the acceleration.
Has the book made an error, or have i misinterpreted the problem?
man, the units don t even work out right for the answer the book gave. that s a sure fire way to tell a wrong answer.
plus, i didn t see any mistakes in your work.
  • · Replies 23 ·
  • · Replies 39 ·
