Porblem about dynamic applications of torque
The discussion focuses on calculating the linear acceleration, angular acceleration of a pulley, and the distance a falling bucket drops over 1.5 seconds. The problem involves a 2.85 kg bucket attached to a disk-shaped pulley with a radius of 0.121 m and mass of 0.742 kg. Key equations utilized include Newton's second law (F = ma) for linear acceleration and the torque equation (τ = Iα) for angular acceleration, with the moment of inertia calculated as I = 1/2mr^2. The distance dropped by the bucket is determined using the kinematic equation d = 1/2at^2.
  • Understanding of Newton's second law (F = ma)
  • Knowledge of torque and angular acceleration (τ = Iα)
  • Familiarity with moment of inertia calculations (I = 1/2mr^2)
  • Basic kinematic equations for linear motion
  • Calculate the net force acting on the system to find linear acceleration
  • Determine the tension in the rope connecting the bucket to the pulley
  • Apply the kinematic equation to find the distance dropped by the bucket
  • Explore the relationship between linear and angular acceleration in rotational systems
Students and professionals in physics, mechanical engineering, and anyone interested in dynamics and rotational motion calculations.
wilmerena
Hi, I am working on the following problem:
A 2.85kg bucket is attached to a disk shaped pulley of radius 0.121m and mass of 0.742 kg. If the bucket is allowed to fall,
what is:
linear acceleration, angular acceleration of pulley and,
how far does the bucket drop in 1.5 s?
so far i solved for I = 1/2mr^2
= 1/2 (0.742) 1.21^2
=.0054
now I am not sure how to get the linear acceleration
any tips? :smile:
Start by identifying the forces acting on the pulley and on the bucket. Then apply Newton's 2nd law to each object. (Hint: since the two objects are connected by a rope, how must their accelerations relate to each other?)
Hi there, it seems like you have already made some progress on solving this problem. To find the linear acceleration, you can use the equation F = ma, where F is the net force acting on the system and m is the total mass of the system. In this case, the only force acting on the system is the weight of the bucket, which can be calculated as mg, where g is the acceleration due to gravity (9.8 m/s^2). So, the net force would be mg - T, where T is the tension in the rope connecting the bucket to the pulley. You can then set this equal to ma and solve for a.
To find the angular acceleration of the pulley, you can use the equation τ = Iα, where τ is the net torque acting on the pulley and I is the moment of inertia that you calculated. The net torque in this case would be equal to the tension in the rope multiplied by the radius of the pulley. You can then set this equal to Iα and solve for α.
To find the distance the bucket drops in 1.5 seconds, you can use the equations for linear motion with constant acceleration, such as d = 1/2at^2 + v0t + d0, where a is the linear acceleration you calculated, t is the time (1.5 seconds in this case), v0 is the initial velocity (which is 0 in this case), and d0 is the initial position (which is also 0 in this case). This will give you the distance the bucket drops in 1.5 seconds.
I hope this helps and good luck with your problem! If you have any other questions, please let me know.
  • · Replies 30 ·
  • · Replies 60 ·
