Thread Closed
Concept of 3 balls falling from building at different angles
Share Thread Thread Tools
Nov24-09, 02:23 PM   #1
If a ball is thrown upwards, another straight out, and another downwards, which will reach the ground with the highest velocity? After thinking about this for a while my conclusion is that they all will have the same velocity since they all have the same initial gravitational potential energy. Am I on the right track?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Nov24-09, 02:34 PM   #2
Mentor
Yes. Assuming they all are given the same initial speed, you are correct.
Nov24-09, 02:49 PM   #3
Thank you very much for the input. I'm glad I found this forum, it seems to be an excellent resource.
Nov24-09, 02:56 PM   #4
No ha ha
It depends on what velocitys they are being launched at, and im assuming that you are neglecting friction.
So lets say they all have the same initial velocities and start at 50 meters up. The starting velocities are 10m/s.
Vertical Launch: So we must first find out how high it goes before it stops and then starts heading back down to earth. I have calculated using the formula H(height)= Vi(initial veritcal velocity)T(time)+1/2(-9.8[acceleration due to gravity])(T2) here it is without the writing H=Vi*T-1/2*(9.8)*T2..... I got that it reached 55.102 meters. The using PE=KE i got that it will have a speed of 32.863 m/s
Horizontal launch: So here it gets complicated but i will give you two answers, first its overall velocity cause it will have both an X-axis component, its initial veloctiy, and a Y-axis component. The second is just the Y-axis part. So I use the equation 2HG(acceleration due to gravity)= Vfinal2-Vinitial2 to find the final vertical velocity. And i get 31.305 m/s. Thats just the Y-axis componet. the overall speed is 32.863 m/s
Straight down launch: I will use the same method as Horizontal launch to find the final velocity here. (use same formula) and i get that the final speed is 32.863..........
Im a little bit shocked at what im getting but all my numbers are correct. So it seems that yes they will all hit the ground with the same speed...... That is that they have all been launched at the same initial speed
This is kinda cool and weird to me ha ha, Hope this answers your question
Nov24-09, 04:29 PM   #5
Nice
Nov24-09, 11:30 PM   #6
Recognitions:
Homework Helper Homework Help
One thing that could have been noted, that for the ball thrown upwards, eventually it returns back to the point from where it was thrown from, with the same speed, but now downwards, so it should be clear that the upwards and downwards case is the same.
The horizontal case isn't so obvious unless you take into account that the total energy, KE + GPE is the same as the upwards and downwards case. This assumes that the object's speed isn't fast enough that curvature of the earths surface would be significant.
Nov24-09, 11:41 PM   #7
Quote by Jeff Reid View Post
Uh, really?
Nov25-09, 06:03 AM   #8
Quote by cesiumfrog View Post
Uh, really?
well yeah, if you threw it hard enough it would never hit the ground as it would reach escape velocity (I know its not being thrown in the most efficient direction to exit the earths pull but it still has a Z component meaning it can be done with enough force)
I think you are looking at a lot of decimal ponts before it's a factor in the real world, but it's worth mentioning
Nov25-09, 07:53 AM   #9
Wow... at first I was very confused, now I get it. Interesting problem!
Thread Closed
Tags
angles, potential energy, velocities
Thread Tools
Similar Threads for: Concept of 3 balls falling from building at different angles
Thread Forum Replies
Dynamics, falling balls. Introductory Physics Homework 4
Two balls falling and bouncing one off the other Introductory Physics Homework 22
2 balls dropped from a building Introductory Physics Homework 1
Falling from a Building Introductory Physics Homework 2
Gravity And Balls Falling Introductory Physics Homework 5
