Uniform elecric fields- force and kinetic energy
The discussion revolves around the effects of increasing the separation between conducting plates in a uniform electric field, specifically focusing on the force experienced by a charge and the corresponding gain in kinetic energy. The context includes theoretical considerations and mathematical reasoning related to electric fields and capacitors.
  • Exploratory, Technical explanation, Mathematical reasoning
  • One participant suggests that increasing the distance between the plates would decrease the force acting on a charge, based on the formula F = VQ/d.
  • Another participant presents a formula for the stored energy in a capacitor and argues that if the charge (Q) is invariant, the force is independent of the separation distance.
  • A clarification is made regarding the scenario of a particle being released from the upper plate of the conducting plates in a vacuum.
  • Further elaboration indicates that if the charge is constant and the separation increases, the voltage between the plates increases linearly.
  • One participant proposes a method to generate high voltage by charging the plates at a smaller separation and then increasing the distance.
Participants express differing views on the relationship between force, separation, and voltage, indicating that multiple competing perspectives exist without a clear consensus.
Some assumptions regarding the invariance of charge and the conditions under which the voltage changes are not fully explored, leaving room for further discussion.
chanderjeet
what is the effect on the force as well as the gain in kinetic energy if the separation of the conducting plates is increased?
I'm thinking that since F= VQ/d if the distance increases then the force would decrease. I could be wrong.
Since, the gain in KE is equivalent to the work done =Fd and since F decreases (I assume) then the KE would also decrease.
The stored energy in a capacitor is
W = (1/2)CV2= (1/2)Q2/C = (1/2)xQ2/e0A
where x = separation and A = area.
So Fx= (dW/dx)= (1/2)Q2/e0A
So if Q is an invariant, the force is independent of separation.
Also Fx = dW/dx = d/dx(1/2)CV2=(1/2)e0AV2 d/dx(1/x)= -(1/2)e0AV2/x2
where V is held constant.
Bob S
sorry, i didn't specify. I was referring to, say, a particle being released at the upper plate of horizontal parallel conducting plates. (in a vacuum)
In this case, Q=CV
so V = Q/C = Qd/e0A
where A = area and d the separation
so if Q = constant, and d is increased, the voltage between the plates increases linearly.
One way to generate high voltage between the plates is to charge them up when d is small, then separate the two plates.
Bob S
  • · Replies 54 ·
  • · Replies 77 ·
  • · Replies 16 ·
