Solve Equation Problem 2: Find a+b+c
  • Thread starter Thread starter 1/2"
The problem involves the equation a² + b² + c² = 2(a - b - c) - 3, with the goal of finding the sum a + b + c.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss completing the square for the variables a, b, and c. Some express confusion about the steps involved and seek clarification on the implications of their manipulations.
There is an ongoing exploration of the implications of the completed square form, with some participants noting that the sum of squares must equal zero. Guidance has been offered regarding the nature of squares and their non-negativity, leading to further questioning about possible values for a, b, and c.
Participants are grappling with the constraints of the problem, particularly regarding the conditions under which the sum of squares can equal zero and the implications for the values of a, b, and c.
1/2"
The problem is a 2+b 2+c 2=2(a-b-c)-3
Find a+b+c
none
well i tried to add 2(ab+ac+cb) to make the a 2+b 2+c 2=(a+b+c) 2
so the other side also has a 2(ab+ac+cb)
:. it becomes( if brackets are opened)
2a-2b-2c+2ab+2ac+2cb-2-1
=2a+2ab+2ac-2b-2c-2+2cb-1
=2a(1+b+c)-2(1+b+c) +2cb-1
= (1+b+c)(2a-2)+2cb-1
Hey i even close to any proper solution
Plz help me out!
a2 + b2 + c2 = 2a - 2b - 2c - 3
<==> a2 - 2a + b2 + 2b + c2 + 2c = -3
Now complete the square in the a terms, b terms and c terms. You should be able to solve for a, b, and c after that.
I am sorry but I dont't get it.
Could you please be more elobrate.It would be rather better if you could just work out only 1 more step.
(a2 -2a + ?) + (b2 + 2b + ?) + (c2 + 2c + ?) = -3
Complete the square in each parenthesized group. Whatever you add on the left side, make sure you add the same amount on the right side.
I've tried it like this
(a 2-2a+1)+(b2 + 2b + 1) +(c2 + 2c + 1) = -3 +1+1+1
<==>(a-1)2+(b+1)2+(c+1)2=0
Is that ok??or is it wrong??:rolleyes:
So what do I do after this??:rolleyes:
Yes, that's right, but you're not quite done. The square of any real number is >= 0. So for example, (a - 1)^2 >= 0, and if (a - 1)^2 > 0, what does that say about the other two terms on the left side of the equation?
So does that mean
(b+1)>0 and (c+1)>0(??)
But what does that conclude?
Look at the equation (a-1)2+(b+1)2+(c+1)2=0: it says the sum of three squares is 0. None of the squares can be negative. If even one of the squares is positive, what happens?
Well i can't guess it any more(SORRY!)
please work out the next step
Do you mean to say :eek:
(a-1)^2=0
=>a-1=0
=>a=1
Similarly b=-1 c=-1
and so a+b+c= -1
But I still have a doubt why can't we consider (a-1)^2= 3or 45 or 1or any positive integer
cuz you said
"The square of any real number is >= 0":confused:
And ideasrule also makes a point.
I 'm a bit confused !
I would be happy if you help!
If (a-1)^2 = 3 you would need one of the other expressions to be negative for the sum to be 0 - but squares can be only positive...
Thanks!
  • · Replies 47 ·
