How to Find Indefinite Integral Using U-substitution
The discussion revolves around finding the indefinite integral of the function sin(2x)/cos^4(2x) using u-substitution. Participants are exploring the appropriate substitutions and simplifications necessary to solve the integral.
  • The original poster attempts to use u = cos^4(2x) but questions the presence of x in the substitution. Another participant suggests a different substitution, u = cos(2x), which leads to a new approach. The discussion includes checking the correctness of the integral after substitution.
Participants are actively engaging with different substitution methods and checking each other's reasoning. Some guidance has been offered regarding the choice of substitution, and there is a focus on verifying the results through differentiation.
There is an indication of confusion regarding the complexity of the problem and the appropriateness of the chosen substitution. The original poster expresses uncertainty about the manipulation of variables and the overall approach to the integral.
mattmannmf
Using U-substitution find the indefinite integral of:
[sin(2x)/cos^4(2x)] dx
So I do know that it will have to come out to it being ln... here's what i did so far
ok so i made u= cos^4(2x)
du= -8cos^3(2x)*sin(2x)dx...(just took the derivative of u and simplified it)
so made sin(2x)dx= du/(-8cos^3(2x))...so i can substitute it into my equation.
so it came out to be:
du/(u*-8cos^3(2x))...but in using u-substitution, i should not have an x variable...
So do i have to minipulate u=cos^4(2x) to get x by its self?
I get x= .5cos^-1(4sqrt(x))
It just seems like its sooooo complicated.. don't know.
No, it definitely won't come out being ln(something).
That's because you're making it too complicated by using the wrong substitution. Instead, use u = cos(2x).
ok thanks...
So u=cos(2x)
-du/2= sin(2x) dx...then i substitute:
=-1/2[integral]du/u^4
where i get =-1/2[integral] u^-4du
=-1/2*-1/3u^-3+C
=1/6u^-3+C
Is that correct?...then i can just substitute what u equals into the equation (since they started in terms of x, ill leave it in terms of x)
Right. And after you undo your substitution you can check your answer. Its derivative should be [sin(2x)/cos^4(2x)].
  • · Replies 22 ·
  • · Replies 105 ·
13K
