Simplifying the Derivative of a Complex Rational Function
The discussion revolves around finding the derivative of a complex rational function, specifically y=(sqrt(8x^4-5))/(x-1). Participants are exploring methods of differentiation and simplification.
  • Mixed
  • Participants discuss the use of logarithmic differentiation versus traditional differentiation methods, with some questioning the original poster's approach and suggesting a different method.
There is an ongoing exploration of differentiation techniques, with some participants providing guidance on using logarithmic properties. The original poster acknowledges their method but is seeking further clarification on simplification.
Participants are navigating the complexities of differentiation rules and the implications of their chosen methods, with some noting potential oversights in the application of the chain rule.
mattmannmf
find derivative of
y=(sqrt(8x^4-5))/ (x-1)
ok...after working out the tricky calculations i get for my final answer:
(32x^4sqrt(8x^4-5)-64x^3sqrt(8x^4-5)) / (16x^6-32x^5+ 16x^4-10x^2+20x-10)
I don't know if you want to do the math...im just wondering if i can simplify it anymore. thanks
I'm pretty sure you didn't do this problem the way you were supposed to. Judging by the title of the thread, you are supposed to do logarithmic differentiation, and I don't see any evidence that you have done this. Instead, it looks like you used the chain rule first and then the quotient rule.
[tex]y~=~\sqrt{\frac{8x^4 - 5}{x - 1}}[/tex]
[tex]\Rightarrow ln(y)~=~ln \left(\sqrt{\frac{8x^4 - 5}{x - 1}}\right )[/tex]
Use the properties of logarithms to write the right side as a difference, and then differentiate with respect to x.
well what i did was (going from your previous equation):
ln(y)= ln(sqrt(8x^4-5)) - ln(x-1)...then i just took the derivative and it pretty much eliminated all the ln
On the left side of the equation you should get 1/y * y'. Did you forget to use the chain rule?
oh no...i added that... i just forgot to put it up in my above equation
  • · Replies 21 ·
