Why would an object become lighter under water?
  • Thread starter Thread starter Kaxa2000
    Water
When an object is submerged in water, it experiences a buoyant force equal to the weight of the water it displaces. For example, a 1 cubic meter object displaces 1000 kg of water, resulting in an upward force of 1000 kg acting on it. This buoyant force offsets the object's weight, making it appear lighter underwater. However, lowering the object further into the water does not increase the buoyant force, as it continues to displace the same volume of water, thus maintaining the same upward force regardless of depth.
  • Understanding of Archimedes' Principle
  • Basic knowledge of buoyancy and density
  • Familiarity with the concept of pressure in fluids
  • Knowledge of the relationship between volume and displacement
  • Research Archimedes' Principle in detail
  • Explore the effects of fluid density on buoyancy
  • Study the relationship between pressure and depth in fluids
  • Investigate applications of buoyancy in engineering and design
Students studying physics, educators teaching fluid mechanics, and anyone interested in understanding the principles of buoyancy and displacement in fluids.
Kaxa2000
If you suspend a large object beneath surface of a lake...it seems to weigh less than if it was above...why is this? Would it become even lighter if you kept lowering it into the water?
The object's weight is offset by the weight of water it displaces. If the object is 1 cubic metre, it will displace 1000kg of water. That 1000kg of water will try to push its way back into the space occupied by the object. In doing so, it will push up on the object with a force of 1000kg.
An object of sufficient rigidity will not get lighter if it is pushged deeper below the surface since it will displace no more than 1000kg of water at any depth.
Unless this is homework.
In which case: what are your thoughts?
Kaxa2000 said:
..why is this?
Why is a very good question.
The simple answer is that there is an upward force equal to the weight of the water displaced - but that doesn't really explain why!
The important thing to understand is that under the water the pressure acts in all directions.
If you had a cube of water under the surface there is a force upward exactly equal to the weight of the cube of water.
The water doesn't move so the force up must be equal to the weight of this cube.
No remove the cube and replace it with another cube of another material.
The force upward doesn't change - so the new cube has an upthrust equal to the weight of the cube of water
No - assuming the density of the water doesn't change
  • · Replies 66 ·
  • · Replies 16 ·
