What angle does it scatter at if the yellow ball is scattered
  • Thread starter Thread starter drkidd22
    Angle Ball
The problem involves an elastic glancing collision between two balls of different masses, where the initial conditions include the speed of the white ball and the rest state of the yellow ball. Participants are tasked with determining the scattering angle of the yellow ball after the collision.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore momentum conservation equations and question the application of these principles in both x and y directions. There are discussions about the correct interpretation of elastic collisions and the conservation of kinetic energy.
Some participants have provided hints and guidance regarding the use of conservation laws, while others express confusion about the calculations and the equations being used. There is an ongoing exploration of the correct values and methods to apply in the context of the problem.
Participants note the importance of direction in momentum conservation and the implications of the elastic nature of the collision. There is mention of specific values derived during the discussion that may not be universally agreed upon.
drkidd22
The white ball (2kg) in the figure has a speed of 1.74 m/s and the yellow ball (1kg) is at rest prior to an elastic glancing collision. After the collision the white ball has a speed of 1.37 m/s. what angle does it scatter at if the yellow ball is scattered at 280 degrees?
mva=mvacos(@)+mvbcos(@)
2(1.37)Cos(@)a+0.58Cos280
2.74Cos@+.10
=92 degrees
I think I'm close, but not quite.
anyone please, a hint?
That's momentum conservation in one direction. What about the other? And what about the fact that the collision is elastic?
2.74Cos@+.10
=92 degrees
I don't understand what you're doing here. I don't see the full equation being used. Where did you get '1.37' and '0.58'? Show all your steps.
1.37 is given as the speed of ball a after the collision.
0.58 is what I had found the speed of ball b to be after collision, but I think it's not correct as I'm not sure how to really do this problem. I can't really understand what the author of the book is trying to say on a similar problem.
OK.
How did you get this? (Hint: That's where the fact that the collision is elastic will come in handy.)
ok, so I think .58 was incorrect.
mava+mbvb = mava'+mbvb'
2(1.74)+0=2(1.37)+vb'
.74m/s = vb'
Right?
When I put this in I still don't get the right answer.
2(1.37)Cos(@)+.74Cos280
2.74Cos@+.13
=92.72 degrees
.74m/s = vb'
Right?
No. That equation isn't valid. (Momentum is a vector--direction matters.)
Instead, make use of the fact that the collision is elastic. What does that mean?
KE is also conserved
Right! Use that to determine the speed of the yellow ball after the collision.
3.0276 = 1.8769 + .5(v^2)
(3.0276 - 1.8769)/(.5) = v^2
Vb' = 1.51 m/s
Vb' = 1.51 m/s
Looks good. (I get 1.52, when I round off.)
0 = 2(1.37)Sin@+1.52Sin280
0 = 2.74Sin@ - 1.50
= 33 degree
I think that's right.
Thanks a million. Took me while to understand it, but I got it. Thanks.
  • · Replies 23 ·
  • · Replies 24 ·
  • · Replies 20 ·
