Why Do Euler's Equalities Hold True?
  • Context: Graduate
  • Thread starter Thread starter coki2000
The discussion centers around the mathematical equalities involving infinite series, specifically the alternating series (1 - 1 + 1 - 1 + ...) and the series of reciprocals of squares (1/1^2 + 1/2^2 + 1/3^2 ...). Participants seek to understand the reasoning behind these equalities and the validity of the methods used to derive them.
  • One participant questions the validity of treating the first series as a geometric series, noting that the formula is only valid for |r| < 1 and that the sequence of partial sums does not converge.
  • Another participant emphasizes that Euler's approach to these series was unconventional and suggests that his methods, while yielding useful results, may not adhere to standard definitions of convergence.
  • There is a request for clarification on why the average of the partial sums is taken in the context of the first series.
  • A participant asks for the solution to the second equality, indicating a desire for further explanation on the series summing to π²/6.
  • A link to an external resource on the Basel problem is provided for additional context.
Participants express differing views on the validity of the methods used to derive the equalities, particularly regarding the first series. There is no consensus on the appropriateness of Euler's techniques or the interpretation of the results.
Participants highlight limitations in the definitions and assumptions surrounding the convergence of infinite series, particularly in the case of the first series. The discussion remains open regarding the interpretation of these mathematical concepts.
coki2000
Hello,
Can you explain to me why
[tex](1-1+1-1...)=\sum_{n=0}^{\infty}(-1)^n=\frac{1}{2}[/tex]
and
[tex](\frac{1}{1^2}+\frac{1}{2^2}+\frac{1}{3^2}...)=\sum_{n=1}^{\infty}\frac{1}{n^2}=\frac{\pi ^2}{6}[/tex]
I don't understand these equalities.Thanks.
The first is being treated as a geometric series:
[tex]\sum_{n=0}^1 r^n= \frac{1}{1-r}[/tex]
Taking r= -1 gives 1/(1-(-1))= 1/2.
Of course, that formula is really only valid for |r|< 1. And by the normal definition of "sum of an infinite series", limit of partial sums, the sequence of partial sums is 1, 0, 1, 0, ... which doesn't converge. So that's strectching a point, at least.
But why do we use this formula because this is wrong for r=-1.And why do you take the average of the partial sums(1,0,1...).Thanks for your helps.
Because Euler decided to do it! As I said, that is NOT a valid calculation using normal definitions. Euler was famous for "playing fast and loose" with sequences and series- and getting useful, if not "correct" results.
Okey.Thanks.
What is the solution of second equality?
  • · Replies 16 ·
