C++ newbie qu: grid construction for finite difference
The discussion focuses on constructing a 2-D grid in C++ for solving finite difference problems related to coupled fluid flow and chemical reactions. The user seeks guidance on linking a struct of fluid properties, such as density, to the grid. A solution is provided by creating a class, GridFluid, which encapsulates both the Grid2D and the fluid properties struct, allowing for easy access to fluid properties through the fluidProperties() method.
  • Understanding of C++ class and template syntax
  • Familiarity with dynamic memory management in C++
  • Basic knowledge of finite difference methods
  • Concept of structs in C++ for organizing data
  • Study C++ dynamic memory management techniques
  • Learn about C++ templates and their applications
  • Explore finite difference methods in computational fluid dynamics
  • Investigate the use of structs and classes for data encapsulation in C++
C++ developers, computational scientists, and engineers working on fluid dynamics simulations who need to implement grid structures and manage associated properties efficiently.
bzz77
Hello everyone:
I am a C++ newbie; I am interesting in using C++ in my work on coupled fluid flow-chemical reaction problems. I apologize in advance for what is probably a very simple question. I would very much appreciate any help to get me on the right track!
My goal is to come up with C++ code for solving a finite difference problem. To do this, I need to (1) construct a 2-D grid and (2) link a struct of data (fluid properties, like density) to the grid. At some point, as I become more experienced, I'd like to learn how to use pointers and iterators, etc, but for now I would like to keep things as simple as possible.
Using some examples, I have come up with a way of constructing a grid that mostly makes sense. But I cannot figure out how to link the grid with a struct of fluid properties. Sorry--I'm certain this is a simple thing to do. If anyone has any suggestions, I would love to hear them. Once I have this problem sorted out, I have a couple of further questions about the grid construction. Thanks a lot.
Here is my grid:
template <typename T>
class Grid2D
public:
Grid() : xsize_(0), ysize_(0), grid_(0) { }
Grid(double xsize, double ysize) : xsize_(xsize), ysize_(ysize), grid_(new T[ xsize_ * ysize_ ]) { }
~Grid() { delete[ ] grid_; }
Create(double xsize, double ysize)
xsize_ = xsize;
ysize_ = ysize;
grid_ = new T[ xsize_ * ysize_ ];
Resize(double xsize, double ysize)
xsize_ = xsize;
ysize_ = ysize;
delete[ ] grid_;
Delete()
xsize_ = 0;
ysize_ = 0;
delete[ ] grid_;
grid_ = 0;
double xsize() const { return xsize_; }
double ysize() const { return ysize_; }
T& operator(double x, double y) { return grid_[ y*xsize_ + x ]; }
const T& operator(double x, double y) const { return grid_[ y*xsize_ + x ]; }
private:
double xsize_, ysize_;
T* grid_;
Technology news on Phys.org
To link the grid with a struct of fluid properties, you could create a class that contains both the Grid2D and the struct. For example: class GridFluid{public:GridFluid() : grid_(0), fluidProperties_(0) {}GridFluid(double xsize, double ysize) : grid_(xsize, ysize), fluidProperties_() {}~GridFluid() { delete[ ] grid_; } Grid& grid() { return grid_; } const Grid& grid() const { return grid_; } FluidProperties& fluidProperties() { return fluidProperties_; } const FluidProperties& fluidProperties() const { return fluidProperties_; } private: Grid grid_;FluidProperties fluidProperties_;};Now when you need to access the fluid properties, you can simply call the GridFluid object and use the .fluidProperties() method. Hope this helps!
  • · Replies 23 ·
  • · Replies 17 ·
  • · Replies 23 ·
  • · Replies 31 ·
