| Thread Closed |
Finding formula for normal vector of surface |
Share Thread | Thread Tools |
| Nov29-09, 10:45 AM | #1 |
S is surface of upper half of sphere (rad 3) at (0,0,0). Find the formula for n (in Cartesian, spherical, and cylindrical coord syst), then evaluate [tex] \int\int\textbf{F}\cdot\textbf{n}dA [/tex] Where F(x,y,z) = k 2. Relevant equations 3. The attempt at a solution in a previous problem, if I let z = f(x,y) be the surface and take [tex] \psi(x,y,z) = f(x,y) - z [/tex] Since [tex] \nabla\psi [/tex] is orthogonal to the surface on which [tex] \psi [/tex] is constant, then I can use this to get the formula for the normal to the surface. Problem is, I'm stuck trying to figure out what the formula for the surface is to start with. A sphere with radius 3 is just x2+y2+z2 = 3 so [tex] z = 3 - \sqrt{x^{2}+y^{2}} [/tex] where 0< x,y < 3 now [tex] \textbf{n} = \frac{\nabla\psi}{\left\|\nabla\psi\right\|} [/tex] Am I on the right track? The unit normal vector field gets pretty ugly after this step :-/ |
| Nov29-09, 10:55 AM | #2 |
It can't be that bad, can it?
BTW, using implicit differentiation then solving for the derivative is often much simpler that solving for the variable and differentiating that. By the way, surely you know enough about spheres to have an easy way of finding the unit normal? |
| Nov29-09, 11:11 AM | #3 |
I must have done something wrong because I've gotten something pretty heinous.
[tex] \nabla\psi = -x(x^{2} + y^{2})^{-1/2}\textbf{i} - y(x^{2} + y^{2})^{-1/2}\textbf{j} - \textbf{k} [/tex] [tex]\left\|\nabla\psi \right\| = (x^{2} + y^{2}) + 1 [/tex] |
| Nov29-09, 11:27 AM | #4 |
I believe that is wrong, but what's so "heinous" about that expression?
The correct one has the same sort of appearance.
| Nov29-09, 11:32 AM | #5 |
Maddeningly unhelpful :(
"By the way, surely you know enough about spheres to have an easy way of finding the unit normal? " Obviously not, can you expound a little? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Finding formula for normal vector of surface
| Calculating the normal vector to the surface | Precalculus Mathematics Homework | 1 | ||
| Calculating surface normal vector | General Math | 5 | ||
| vector calculus finding the surface normal | Calculus | 1 | ||
| Unit Normal Vector ... normal, but not normalized? | Calculus | 5 | ||
| Finding the unit tagent vector, normal vec and curvature problem | Calculus & Beyond Homework | 1 | ||
